Keurig K55 Power Cable Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
103
All Time:
2,039
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If your Keurig is unable to turn on, you may need to replace your power cable with this guide.
Tools
    1. Keurig K55 Power Cable Replacement, Power Cable: step 1, image 1 of 2 Keurig K55 Power Cable Replacement, Power Cable: step 1, image 2 of 2
      • Access the bottom of the Keurig by flipping it on its side.
      Ask FixBot
    2. Keurig K55 Power Cable Replacement: step 2, image 1 of 3 Keurig K55 Power Cable Replacement: step 2, image 2 of 3 Keurig K55 Power Cable Replacement: step 2, image 3 of 3
      • Remove the five 13mm Phillips #0 screws securing the bottom case.
      • Pull the silver cover off of the device.
      Ask FixBot
    3. Keurig K55 Power Cable Replacement: step 3, image 1 of 3 Keurig K55 Power Cable Replacement: step 3, image 2 of 3 Keurig K55 Power Cable Replacement: step 3, image 3 of 3
      • To remove the power cable, highlighted in red, follow iFixit's guide on soldering.
      • The ground cable, highlighted in orange, needs to be re-soldered to your new power cable.
      Ask FixBot
William O'Brien
500 Reputation
4 Guides authored
Cal Poly, Team S1-G3, Livingston Winter 2018 Member of Cal Poly, Team S1-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 103
All Time: 2,039
