Up to 20% off select tools
Keurig K40 Spring Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
115
All Time:
5,483
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
To get to the spring the K-cup assembly housing, the lid, and the water pump will need to be removed.
    1. Keurig K40 Spring  Replacement, Spring: step 1, image 1 of 2 Keurig K40 Spring  Replacement, Spring: step 1, image 2 of 2
      • Using a Phillips #2 screwdriver unscrew two 2mm screws.
      • Once the screws are out, lift up and squeeze the k-cup assembly housing to take it out.
      Ask FixBot
    2. Keurig K40 Spring  Replacement: step 2, image 1 of 1
      • Use the handle to open the lid then squeeze and move the lid around to take it off.
      Ask FixBot
    3. Keurig K40 Spring  Replacement: step 3, image 1 of 3 Keurig K40 Spring  Replacement: step 3, image 2 of 3 Keurig K40 Spring  Replacement: step 3, image 3 of 3
      • Using the Phillips #0 screwdriver unscrew two 2mm screws on the water pump.
      • Once unscrewed lift the water pump up and pull and twist it off.
      Ask FixBot
    4. Keurig K40 Spring  Replacement: step 4, image 1 of 2 Keurig K40 Spring  Replacement: step 4, image 2 of 2
      • Using the tweezer and the plastic opening tool grab the front of the spring to take it off.
      Ask FixBot
Author
with
Michelle Sanchez
165 Reputation
1 Guide authored
USF Tampa, Team 6-1, Eyestone Spring 2016 Member of USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 115
All Time: 5,483
