Keurig K40 Open/Close Sensor Replacement
    1. Keurig K40 Open/Close Sensor Replacement, Top Water Pump: step 1, image 1 of 1
      • Begin by removing the top cover from the device.
      • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
      Ask FixBot
    2. Keurig K40 Open/Close Sensor Replacement: step 2, image 1 of 1
      • Unscrew both 1.5mm screws located on the water pump.
      Ask FixBot
    3. Keurig K40 Open/Close Sensor Replacement: step 3, image 1 of 2 Keurig K40 Open/Close Sensor Replacement: step 3, image 2 of 2
      • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
      • The water pump and pipe should now be loose and easy to move as shown.
      Ask FixBot
    4. Keurig K40 Open/Close Sensor Replacement: step 4, image 1 of 2 Keurig K40 Open/Close Sensor Replacement: step 4, image 2 of 2
      • Pull on the point where the pipe meets the water pump.
      • The pipe will come loose and the water filter will be free and ready to be replaced.
      Ask FixBot
    1. Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: step 5, image 1 of 2 Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: step 5, image 2 of 2
      • Using a #2 Philips head screwdriver remove the 1.2mm screw holding the sensor in place.
      • Locate where the connections are soldered to the sensor
      Ask FixBot
    2. Keurig K40 Open/Close Sensor Replacement: step 6, image 1 of 1
      • Melt the solder that is connected to the sensor.
      • Be careful to avoid any rubber and try to only contact the metal making the connection.
      Ask FixBot
    3. Keurig K40 Open/Close Sensor Replacement: step 7, image 1 of 1
      • Put the replacement sensor back on the post that holds it and begin to solder the two metal connections back to the sensor.
      • Be careful not to touch the end of the soldering iron.
      Ask FixBot
jonathan
816 Reputation
2 Guides authored
USF Tampa, Team 6-1, Eyestone Spring 2016 Member of USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Members
60 Guides authored
1 Guide Comment
Where can I get the open/closed sensor? I called Keurig and they told me they don’t handle them.
John Fictum - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 117
All Time: 4,749
