Keurig K40 Bottom Water Filter Replacement
    1. Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: step 1, image 1 of 2 Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: step 1, image 2 of 2
      • Flip the device on its side so that the metal faces you.
      • Begin by unscrewing the five 1.5mm bottom screws with a #0 phillips head screwdriver.
      Ask FixBot
    2. Keurig K40 Bottom Water Filter Replacement: step 2, image 1 of 2 Keurig K40 Bottom Water Filter Replacement: step 2, image 2 of 2
      • Once the base is unscrewed, remove the base from the plastic wedges used to hold it in place.
      • The wires do not need to be cut as this repair will not harm or use them.
      Ask FixBot
    3. Keurig K40 Bottom Water Filter Replacement: step 3, image 1 of 2 Keurig K40 Bottom Water Filter Replacement: step 3, image 2 of 2
      • Using a size 0 Philips head screwdriver, remove two 1.2mm screws that hold the filter in place.
      • Pull the pump back to remove it from the slot it was in.
      Ask FixBot
    4. Keurig K40 Bottom Water Filter Replacement: step 4, image 1 of 1
      • Grip where the filter and the flow line connect and pull apart until they are separated.
      • Clean or obtain a new filter and put back together. This is done by repeating the steps in reverse, putting the device back together.
      Ask FixBot
14 other people completed this guide.
jonathan
816 Reputation
2 Guides authored
USF Tampa, Team 6-1, Eyestone Spring 2016 Member of USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Members
60 Guides authored
13 Guide Comments
Where do you obtain a new filter?
Anthony Montoya - Reply Share
I have the same question as Anthony. Every Keurig filter I see is the charcoal filter that takes 2 seconds to change
Matt Baum - Reply Share
[|i have the same question as well.. I don’t see anywhere selling a new filter…]
eddie mayfield - Reply Share
I need the filter, where do I buy a new Filter?
Gladys Karina Andino - Reply Share
The answer seems to be: “You don’t.”
Van Davis - Reply Share
Past 24 Hours: 7
Past 7 Days: 40
Past 30 Days: 187
All Time: 38,315
