Keurig K10 MINI PLUS Handle Replacement
    1. Keurig K10 MINI PLUS Handle Replacement, Top Needle: step 1, image 1 of 2 Keurig K10 MINI PLUS Handle Replacement, Top Needle: step 1, image 2 of 2
      • Remove two 9 mm Phillips #1 screws.
      • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
      • The screws are located on the top of where the K-Cup would be.
      Ask FixBot
    2. Keurig K10 MINI PLUS Handle Replacement: step 2, image 1 of 3 Keurig K10 MINI PLUS Handle Replacement: step 2, image 2 of 3 Keurig K10 MINI PLUS Handle Replacement: step 2, image 3 of 3
      • Once you remove the screws, the top cover should come out.
      • The back of the cover is held in place by two locking tabs. To remove the cover, pull it back slightly and it should come free.
      • You will then want to remove these screws which are the same size.
      • The needle is sharp, so be careful.
      Ask FixBot
    3. Keurig K10 MINI PLUS Handle Replacement: step 3, image 1 of 1
      • Once you get those removed, you are going to want to pull on the hose until it pops off.
      • Once the hose comes off, the needle will fall out by itself.
      • Be careful when picking up the needle as the needle is sharp.
      Ask FixBot
    1. Keurig K10 MINI PLUS Handle Replacement, Handle: step 4, image 1 of 1
      • Remove the two Phillips #1 screws.
      • The top needle is intact and there, so be careful when in this area.
      Ask FixBot
    2. Keurig K10 MINI PLUS Handle Replacement: step 5, image 1 of 2 Keurig K10 MINI PLUS Handle Replacement: step 5, image 2 of 2
      • Next, after the removal of the hose on the top by simply pulling it off, remove the following four Phillips #1 screws.
      Ask FixBot
    3. Keurig K10 MINI PLUS Handle Replacement: step 6, image 1 of 1
      • Once you take off the screws, this part of the handle will come off.
      Ask FixBot
    4. Keurig K10 MINI PLUS Handle Replacement: step 7, image 1 of 1
      • To pull this part off, pull inwards with the these tabs located on both sides of the handle assembly.
      Ask FixBot
    5. Keurig K10 MINI PLUS Handle Replacement: step 8, image 1 of 3 Keurig K10 MINI PLUS Handle Replacement: step 8, image 2 of 3 Keurig K10 MINI PLUS Handle Replacement: step 8, image 3 of 3
      • Next, remove these two Phillips #1 screws to allow the release of the actual handle from the frame.
      • For the O rings, we used the plastic prying tools. Just keep in mind that you might want to hold one side of the O ring down while trying to pry off the other side with the other.
      • Once you get the O rings on both sides out, you can pull the handle by pulling on each side.
      Ask FixBot
    6. Keurig K10 MINI PLUS Handle Replacement: step 9, image 1 of 1
      • Once you pull both sides, the handle will come off as shown.
      Ask FixBot
Roberto Maldonado
395 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 45
All Time: 3,005
