Keurig B70 Platinum Base Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
76
All Time:
1,131
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
Cracked base? Or maybe you feel like taking it out for a thorough wash?
This guide will show you how to remove the plastic base surrounding the Keurig B70 Platinum device.
You will need a Phillips #2 screwdriver to complete this guide.
Tools
    1. Keurig B70 Platinum Base Replacement, Base: step 1, image 1 of 2 Keurig B70 Platinum Base Replacement, Base: step 1, image 2 of 2
      • Turn off and unplug the Keurig before starting.
      • Turn the Keurig upside down so the metal base is exposed.
      • Remove the five 12.0 mm screws.
      Ask FixBot
    2. Keurig B70 Platinum Base Replacement: step 2, image 1 of 2 Keurig B70 Platinum Base Replacement: step 2, image 2 of 2
      • Lift the metal plate off the Keurig and hang it over the side of the device.
      • Be careful! The metal plate is sharp!
      • There are wires connected to the metal plate. Make sure the wires are not in the way of the internal components.
      Ask FixBot
    3. Keurig B70 Platinum Base Replacement: step 3, image 1 of 3 Keurig B70 Platinum Base Replacement: step 3, image 2 of 3 Keurig B70 Platinum Base Replacement: step 3, image 3 of 3
      • Remove the three 11.0 mm screws located on the upper left side of the base from within the tub-looking area.
      • Pull out the red and white wires and put it off to the side of the Keurig.
      Ask FixBot
    4. Keurig B70 Platinum Base Replacement: step 4, image 1 of 3 Keurig B70 Platinum Base Replacement: step 4, image 2 of 3 Keurig B70 Platinum Base Replacement: step 4, image 3 of 3
      • Pull out the water collector by gripping it tightly and lifting upwards.
      Ask FixBot
    5. Keurig B70 Platinum Base Replacement: step 5, image 1 of 3 Keurig B70 Platinum Base Replacement: step 5, image 2 of 3 Keurig B70 Platinum Base Replacement: step 5, image 3 of 3
      • Lift the tube, connected to the tank, off the black plastic hook and leave it off to the side of the hook.
      Ask FixBot
    6. Keurig B70 Platinum Base Replacement: step 6, image 1 of 3 Keurig B70 Platinum Base Replacement: step 6, image 2 of 3 Keurig B70 Platinum Base Replacement: step 6, image 3 of 3
      • Pull the power cord out from the plastic holder located near the water tank.
      • This step requires a bit of force so don't be afraid to pull harder!
      Ask FixBot
    7. Keurig B70 Platinum Base Replacement: step 7, image 1 of 2 Keurig B70 Platinum Base Replacement: step 7, image 2 of 2
      • Remove the six 13.0 mm screws.
      Ask FixBot
    8. Keurig B70 Platinum Base Replacement: step 8, image 1 of 3 Keurig B70 Platinum Base Replacement: step 8, image 2 of 3 Keurig B70 Platinum Base Replacement: step 8, image 3 of 3
      • Lift the metal base and hover it over the opening of the black plastic base.
      • Carefully raise the plastic base over the metal base until it is removed.
      • Make sure to pull the power cord through the base as well!
      Ask FixBot
Steven Tran
350 Reputation
2 Guides authored
UW Tacoma, Team S1-G6, Rose Fall 2018 Member of UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 76
All Time: 1,131
