Keurig B60 Puncture Needle Replacement
Views: 32K
View statistics:
Past 24 Hours:
6
Past 7 Days:
35
Past 30 Days:
130
All Time:
31,974
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacing the Puncture Needle is similar to the Handle Replacement, but requires a couple extra steps outlined below.
Tools
    1. Keurig B60 Puncture Needle Replacement, Handle: step 1, image 1 of 1
      • Lift the handle
      Ask FixBot
    2. Keurig B60 Puncture Needle Replacement: step 2, image 1 of 3 Keurig B60 Puncture Needle Replacement: step 2, image 2 of 3 Keurig B60 Puncture Needle Replacement: step 2, image 3 of 3
      • Locate and remove the two 9.5 mm Torx T15 screws on both sides of the handle.
      Ask FixBot
    3. Keurig B60 Puncture Needle Replacement: step 3, image 1 of 2 Keurig B60 Puncture Needle Replacement: step 3, image 2 of 2
      • Remove the broken handle and replace with the new one
      Ask FixBot
    1. Keurig B60 Puncture Needle Replacement, Puncture Needle: step 4, image 1 of 1
      • Locate and remove the two 9.5 mm Phillips #1 screws.
      • Remove the plastic ring around the K-Cup Pack Holder
      Ask FixBot
    2. Keurig B60 Puncture Needle Replacement: step 5, image 1 of 1
      • Remove the two 9.5 mm Phillips #1 screws on the underside of the lid.
      Ask FixBot
    3. Keurig B60 Puncture Needle Replacement: step 6, image 1 of 2 Keurig B60 Puncture Needle Replacement: step 6, image 2 of 2
      • Detach the lid from the Keurig.
      Ask FixBot
    4. Keurig B60 Puncture Needle Replacement: step 7, image 1 of 1
      • Locate and remove the two 9.5 mm Phillips #1 screws on the top of the puncture needle.
      Ask FixBot
    5. Keurig B60 Puncture Needle Replacement: step 8, image 1 of 3 Keurig B60 Puncture Needle Replacement: step 8, image 2 of 3 Keurig B60 Puncture Needle Replacement: step 8, image 3 of 3
      • Squeeze and pull on the hose to remove it from the Puncture Needle
      • Puncture needle should now be exposed
      Ask FixBot
    6. Keurig B60 Puncture Needle Replacement: step 9, image 1 of 3 Keurig B60 Puncture Needle Replacement: step 9, image 2 of 3 Keurig B60 Puncture Needle Replacement: step 9, image 3 of 3
      • Remove the Puncture Needle Assembly from Keurig
      Ask FixBot
7 other people completed this guide.
Jake Wynn
836 Reputation
5 Guides authored
Cal Poly, Team 1-7, Maness Spring 2016 Member of Cal Poly, Team 1-7, Maness Spring 2016
CPSU-MANESS-S16S1G7
5 Members
60 Guides authored
2 Guide Comments
Keurig B60 Puncture Needle Replacement. I need the punture needlees,upper and lower for this model.
johnneypa - Reply Share
I will be completing this guide but where do you get the replacement puncture needles for this model??
John Lawson
John Lawson - Reply Share
Past 24 Hours: 6
Past 7 Days: 35
Past 30 Days: 130
All Time: 31,974
