Kenwood TH-D74A Front Panel Replacement
  1. Kenwood TH-D74A Front Panel Replacement, The Radio when fully functional: step 1, image 1 of 1
    • This is the stock USA model of Kenwood TH-D74A
    Ask FixBot
  2. Kenwood TH-D74A Front Panel Replacement: step 2, image 1 of 1
    • The faceplate has locks to the rear plastic panel on the topmost margin. The bottom part is secured by two philips-head screws. There is an obvious white ribbon connector that must be carefully removed from both ends. The connection is held by a hinge clip. You pick the hinge to raise it up and release the cable end.
    Ask FixBot
  3. Kenwood TH-D74A Front Panel Replacement, Remove the ribbon connector carefully!: step 3, image 1 of 1
    • The plastic tool (seen on R side) is able to pry up the hinge lock that holds the ribbon end to the connector block. Use your fingernail to aid the plastic tool in releasing the hinge lock from pressing on the cable.
    Ask FixBot
  4. Kenwood TH-D74A Front Panel Replacement, Remove the speaker connections: step 4, image 1 of 1
    • Desolder the speaker wires in preparation for removing the keypad assembly
    Ask FixBot
  5. Kenwood TH-D74A Front Panel Replacement, Transfer the foam padding and microphone tube: step 5, image 1 of 1
    • Remove the soft foam padding and the microphone foam tube from the old faceplate. It is glued but can be lifted off with care. Use tiny amounts of cyanoacrylate (Super Glue) to reattach them to the new faceplate
    Ask FixBot
  6. Kenwood TH-D74A Front Panel Replacement, Transfer the spring: step 6, image 1 of 1
    • There is a metal spring that is located on top of the rubber seal that appears to function as an antenna component (maybe a counterpoise) or just a spring lock. Need to transfer this too by prying it out carefully. It is 1.5 inches long
    Ask FixBot
  7. Kenwood TH-D74A Front Panel Replacement, Lift off the plastic keypad panel: step 7, image 1 of 1
    • Start prying out the keypad sheet using the wide metal pick. The glue is a thin line in the periphery of the keypad
    Ask FixBot
  8. Kenwood TH-D74A Front Panel Replacement, continue around the keypad: step 8, image 1 of 1
    • Continue prying carefully and it will reveal the multi-switch board underneath (with copper terminals)
    Ask FixBot
  9. Kenwood TH-D74A Front Panel Replacement, keep aside the keypad: step 9, image 1 of 1
    • Black front keypad removed completely
    Ask FixBot
  10. Kenwood TH-D74A Front Panel Replacement, Lift off the switchboard very carefully!: step 10, image 1 of 1
    • Be carful with this switch or keypad electronic board. Use the plastic picks to aid in lifting the board with progressive lifting from all sides.
    Ask FixBot
  11. Kenwood TH-D74A Front Panel Replacement, work on separating the glue carefully: step 11, image 1 of 1
    • The copper lined switchboard is glued on to the plastic front panel and but be dissected thru using the plastic black tool. Keep inserting the blue picks to maintain distributed pressure to lifting off the board. DO NOT use a metal tool here
    Ask FixBot
  12. Kenwood TH-D74A Front Panel Replacement, set aside the switchboard: step 12, image 1 of 1
    • Switchboard removed completely. DO NOT bend or press on any button while the board is off the plastic panel. This is a thin and sensitive board.
    Ask FixBot
  13. Kenwood TH-D74A Front Panel Replacement, this is the underside of the switchboard: step 13, image 1 of 1
    • This is the underside of the switchboard. Notice the contacts for the speaker and the ribbon connector block
    Ask FixBot
  14. Kenwood TH-D74A Front Panel Replacement, Reconnect the speaker terminals: step 14, image 1 of 1
    • Reconnect the speaker terminals. Wire with black stripe goes to the negative terminal (right side on the photo). Use a small paper tape to keep the wires tidy. NOT IN PHOTO, reconnect the ribbon connector cable. Test the sound, and keypad before locking the faceplate back to chassis
    Ask FixBot
  15. Kenwood TH-D74A Front Panel Replacement, Test buttons, test speaker, and enjoy!: step 15, image 1 of 1
    • Program the frequencies, PL tones, test at low power to reach the repeater; or use 146.52 simplex to test with another radio. Good luck!
    Ask FixBot
2 other people completed this guide.
Attached Documents
Jojo
313 Reputation
1 Guide authored
2 Guide Comments
Half of this repair is missing and the grammar is awful. Remove this tutorial. It says nothing about putting the radio back together. Ridiculous.
Fake Newspapers - Reply Share
I can understand that your title is Fake Newspapers… that is EVIL to me to begin with commenting on your comment. Second, this is a community of positive support, I uploaded half of it, try to add the next half if you figure it out. There was NOTHING before I uploaded this. The grammar got distorted in the upload process, why don’t you correct them and improve the grammar? You attitude is despicable as a third comment. You are likewise ridiculously awful to be in this community. I did not learn anything good from you today. Get out of here.
Jojo - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 38
All Time: 1,025
