Up to 20% off select tools
Kenwood Chef Drive Gear replace
Views: 18K
View statistics:
Past 24 Hours:
25
Past 7 Days:
140
Past 30 Days:
527
All Time:
18,152
Comments: 21
1 comment on steps, 20 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
    1. Kenwood Chef Drive Gear replace, Tools: step 1, image 1 of 1
      • Prepare your Tools.
      Ask FixBot
    2. Kenwood Chef Drive Gear replace, Open Electronic box: step 2, image 1 of 1
      • Remove five Screens T20 from the bottom and lift the bottom plate up.
      Ask FixBot
    3. Kenwood Chef Drive Gear replace, Remove electronic box: step 3, image 1 of 2 Kenwood Chef Drive Gear replace, Remove electronic box: step 3, image 2 of 2
      • Separate nine cables.
      • Remove all screws from the electronic box.
      • Remove the electronic box.
      Ask FixBot
    4. Kenwood Chef Drive Gear replace, Loosen the tilt mechanics: step 4, image 1 of 3 Kenwood Chef Drive Gear replace, Loosen the tilt mechanics: step 4, image 2 of 3 Kenwood Chef Drive Gear replace, Loosen the tilt mechanics: step 4, image 3 of 3
      • Tilt the machine head.
      • Remove the security washer from the hinge axle.
      • Remove the axle and the machine stand.
      Ask FixBot
    5. Kenwood Chef Drive Gear replace, Spring and design plate: step 5, image 1 of 3 Kenwood Chef Drive Gear replace, Spring and design plate: step 5, image 2 of 3 Kenwood Chef Drive Gear replace, Spring and design plate: step 5, image 3 of 3
      • Pull the spring out.
      • Remove the screw.
      • Remove the design plate.
      Ask FixBot
    6. Kenwood Chef Drive Gear replace, Remove cover: step 6, image 1 of 3 Kenwood Chef Drive Gear replace, Remove cover: step 6, image 2 of 3 Kenwood Chef Drive Gear replace, Remove cover: step 6, image 3 of 3
      • Remove four screws T20.
      • Remove the cover.
      Ask FixBot
    7. Kenwood Chef Drive Gear replace, Remove top cover: step 7, image 1 of 3 Kenwood Chef Drive Gear replace, Remove top cover: step 7, image 2 of 3 Kenwood Chef Drive Gear replace, Remove top cover: step 7, image 3 of 3
      • Remove two screws T20.
      • Remove the top cover. Note: the cable connecting the top cover and the lower case is very short.
      • Remove the screws from the "Light on/off"-unit and separate it from the top cover.
      Ask FixBot
    8. Kenwood Chef Drive Gear replace, Remove motor cover: step 8, image 1 of 1
      • Remove three screws T20 and the washers.
      • Take the cover off.
      Ask FixBot
    9. Kenwood Chef Drive Gear replace, Motor: step 9, image 1 of 1
      • Remove three screws T20 and the plastic washers.
      Ask FixBot
    10. Kenwood Chef Drive Gear replace, Remove drive gear: step 10, image 1 of 3 Kenwood Chef Drive Gear replace, Remove drive gear: step 10, image 2 of 3 Kenwood Chef Drive Gear replace, Remove drive gear: step 10, image 3 of 3
      • Using a punch and a hammer push out the pin. (Note: support the gear on the opposite side to protect the the motor shaft from damage).
      • The gear ist free.
      • When inserting the pin, support the gear on the opposite side to protect the the motor shaft from damage.
      Ask FixBot
To reassemble your device, follow these steps in reverse order.
7 other people completed this guide.
Special thanks to these translators:
de en
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Dominik Kübelsbeck
321 Reputation
1 Guide authored
20 Guide Comments
super Anleitung
hat problemlos geklappt
vielen Dank.
PS: ist schon ein bisschen aufwendig, nur um den Antriebszahn zu wechseln, die gesamte Maschine zu zerlegen.
Gruß Rainer
Rainer Jourdan - Reply Share
Great tutorial, however it does not apply for me, as I have a Kenwood titanium KMY60 model, this spare part does NOT have a pin. I can’t say how it is fixed to the gear, could you advice on how to disassemble it?
landrieu - Reply Share
Hi, how did you manage to disassemble the part without the pin? How is it fixed? Thank you!
Christian Bolleter - Reply Share
vielen Dank für die Anleitung. Hat (fast) alles funktioniert, außer das Kabel für das Licht. Es rutscht beim Einsetzen des Oberteils immer wieder ab. Gibt es einen besonderen Tip?
Andre2111 - Reply Share
Danke für die Anleitung. Wir haben angefangen, nach Gutdünken loszuschrauben und sind kläglich gescheitert. Mit der Anleitung hat es geklappt. Vielen Dank dafür!
Ich bin selber Ingenieur und konstruiere mechanische Bauteile und bin doch sehr verwundert, das Kenwood dermaßen kompliziert baut.
Niels Rütthard - Reply Share
Past 24 Hours: 25
Past 7 Days: 140
Past 30 Days: 527
All Time: 18,152
