Kenwood Chef A701A Power Cable Replacement
    1. Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: step 1, image 1 of 2 Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: step 1, image 2 of 2
      • Turn the mixer upside down
      • Remove the two screws holding the white cable grip.
      • Remove the black cable grip. The long screw also holds the cover onto the terminal block
      Ask FixBot
    2. Kenwood Chef A701A Power Cable Replacement, Remove the old cable: step 2, image 1 of 1
      • Remove the cable cover to expose the terminal block.
      • Remove the wires from the live and neutral terminals.
      • Thread the cables out though the cover and then from the mixer chassis
      Ask FixBot
      • To refit simply follow the removal process in reverse
      • Be sure to connect the wires to the correct terminals, Brown - Live, Blue, Neutral.
      • If fitting a new plug ensure it is fitted with the appropriate fuse. If in any doubt consult a compitent electrician/electrical engineer
      Ask FixBot
5 other people completed this guide.
Grant
173 Reputation
1 Guide authored
1 Guide Comment
Important addition: make sure you leave enough cable length free under the mixer for when you raise the top of the mixer during use to change accessories or remove the bowl. Our local electrical repair shop didn’t think to do this and as soon as I raised the top the cable was pulled out.
Karen Leach - Reply Share
Past 24 Hours: 4
Past 7 Days: 41
Past 30 Days: 127
All Time: 11,444
