Kenwood CH250 Coupling Replacement
    1. Kenwood CH250 Coupling Replacement, Coupling: step 1, image 1 of 2 Kenwood CH250 Coupling Replacement, Coupling: step 1, image 2 of 2
      • Remove the small cap covering the screw holding the coupling onto the shaft, using a small flat-head screw driver.
      Ask FixBot
    2. Kenwood CH250 Coupling Replacement: step 2, image 1 of 1
      • Unscrew the screw holding the coupling onto the shaft, using the PH1 screw driver.
      Ask FixBot
    3. Kenwood CH250 Coupling Replacement: step 3, image 1 of 1
      • Drag off the old coupling.
      Ask FixBot
    4. Kenwood CH250 Coupling Replacement: step 4, image 1 of 1
      • Clean any dirt around the shaft.
      Ask FixBot
    5. Kenwood CH250 Coupling Replacement: step 5, image 1 of 2 Kenwood CH250 Coupling Replacement: step 5, image 2 of 2
      • Put the plastic washer onto the shaft, then place the metal washer on top of the plastic washer.
      • Note: the old coupling did not have any washers.
      Ask FixBot
    6. Kenwood CH250 Coupling Replacement: step 6, image 1 of 1
      • Push the new coupling onto the shaft.
      Ask FixBot
    7. Kenwood CH250 Coupling Replacement: step 7, image 1 of 1
      • Secure the coupling with the screw, using the PH1 screw driver.
      Ask FixBot
    8. Kenwood CH250 Coupling Replacement: step 8, image 1 of 1
      • Finally, put the cap on top of the screw and press in place with the flat-head screw driver.
      Ask FixBot
Finish Line
Sebastian Gassner
187 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 41
All Time: 695
