Kenmore Stove Bake Element Replacement
Video Guide
This guide was transcribed from a YouTube video.
      • Unplug the stove from the wall outlet before touching any wiring or internal parts.
      • Let the oven cool completely before reaching inside.
      • Wear work gloves if the panel edges or rusted hardware are sharp.
      Ask FixBot
      • Open the oven door and locate the locking tab on each hinge.
      • Pull both hinge tabs down as far as they will go.
      • Close the door until it stops against the lowered hinge tabs.
      • Grip both sides of the door, lift straight up, and pull it away from the stove.
      • Set the door on a stable surface where it won't fall.
      Ask FixBot
      • Slide each oven rack toward you.
      • Lift the rack and pull it out of the oven.
      • Set the racks aside until reassembly.
      Ask FixBot
      • Locate the two Phillips screws securing the oven bottom panel.
      • Use a Phillips screwdriver to remove the two screws.
      • Keep the washer with each screw for reassembly.
      • Original screws may have flatter heads than replacement screws.
      • If a rusted original screw must be cut off, replace it with an 8-32 screw during reassembly.
      Ask FixBot
      • Insert a flathead screwdriver into one of the screw holes in the bottom panel.
      • Use the screwdriver to lift the rear edge of the panel.
      • Grab both sides of the panel and raise the back edge.
      • Pull the front edge out from under the front lip of the oven cavity.
      • Remove the bottom panel from the stove.
      Ask FixBot
      • Locate the four screws securing the bake element.
      • Two screws are at the front of the element, and two are at the back.
      • Use a 1/4 inch nut driver to remove the four screws.
      • Keep the screws organized for reassembly.
      Ask FixBot
      • Work from the rear of the stove if the back cover is already off from testing.
      • Disconnect the orange wire from one bake-element terminal.
      • Disconnect the yellow wire from the other terminal.
      • Disconnecting the wires from the rear is easier than pulling them through the front openings.
      • Reconnect the orange and yellow wires to the replacement element during reassembly.
      Ask FixBot
      • Return to the inside of the oven.
      • Pull the bake element straight out of the oven cavity.
      • Remove the old bake element from the stove.
      Ask FixBot
Install the replacement bake element by reversing the removal steps. Reconnect the orange and yellow wires before securing the element, reinstall the two washers with the bottom-panel screws, and replace any cut-off rusted screws with 8-32 screws. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 61
All Time: 147
