Kenmore Series 110 Dryer Start Switch Replacement
  1. Kenmore Series 110 Dryer Start Switch Replacement, Remove control console screws: step 1, image 1 of 3 Kenmore Series 110 Dryer Start Switch Replacement, Remove control console screws: step 1, image 2 of 3 Kenmore Series 110 Dryer Start Switch Replacement, Remove control console screws: step 1, image 3 of 3
    • Before you begin, be sure to unplug the dryer.
    • Remove the screws the hold down the control console. There is one screw on each side. The screws are #1 philips.
    Ask FixBot
  2. Kenmore Series 110 Dryer Start Switch Replacement, Open the control panel: step 2, image 1 of 2 Kenmore Series 110 Dryer Start Switch Replacement, Open the control panel: step 2, image 2 of 2
    • Slide the control panel forward in order to expose the control panel controls and wiring.
    • Note the tabs slide into the holes.
    Ask FixBot
  3. Kenmore Series 110 Dryer Start Switch Replacement, Remove the start switch: step 3, image 1 of 2 Kenmore Series 110 Dryer Start Switch Replacement, Remove the start switch: step 3, image 2 of 2
    • The start switch is in the right side of the exposed control panel.
    • Remove the two wire clips from the tabs on the switch. Note black on top white/red on the bottom.
    • Lift the tab on the lower part of the switch and turn to the right to remove.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 30
All Time: 1,657
