Kenmore Model 110 Clutch Replacement
Views: 20K
View statistics:
Past 24 Hours:
7
Past 7 Days:
64
Past 30 Days:
274
All Time:
19,642
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will show you how to replace a worn or broken clutch on the Kenmore Model 110 washing machine. If the device timer shows the cycle has completed but never drained the water or you find that the agitator is not spinning, it could mean the clutch is bad and needs to be replaced.
    1. Kenmore Model 110 Clutch Replacement, Transmission Clutch: step 1, image 1 of 2 Kenmore Model 110 Clutch Replacement, Transmission Clutch: step 1, image 2 of 2
      • Unplug the washing machine.
      • Turn both the hot and cold water supply lines off.
      Ask FixBot
    2. Kenmore Model 110 Clutch Replacement: step 2, image 1 of 1
      • Disconnect the supply hoses using channel lock pliers. Use the towel to catch any water that may spill out.
      Ask FixBot
    3. Kenmore Model 110 Clutch Replacement: step 3, image 1 of 1
      • Use the channel lock pliers to remove tension on the hose spring clamp and pull the drain line from the washer.
      • Water will come out when hose is disconnected.
      Ask FixBot
    4. Kenmore Model 110 Clutch Replacement: step 4, image 1 of 2 Kenmore Model 110 Clutch Replacement: step 4, image 2 of 2
      • Pinch the plastic tabs with the needle nose pliers and push through the metal back panel.
      Ask FixBot
    5. Kenmore Model 110 Clutch Replacement: step 5, image 1 of 1
      • Pull up the control panel located on top of the washer machine.
      Ask FixBot
    6. Kenmore Model 110 Clutch Replacement: step 6, image 1 of 1
      • Lift the plastic tab on the timer wiring harness connector and pull from the timer.
      Ask FixBot
    7. Kenmore Model 110 Clutch Replacement: step 7, image 1 of 2 Kenmore Model 110 Clutch Replacement: step 7, image 2 of 2
      • Disconnect the hose and wiring harness from water level control.
      Ask FixBot
    8. Kenmore Model 110 Clutch Replacement: step 8, image 1 of 3 Kenmore Model 110 Clutch Replacement: step 8, image 2 of 3 Kenmore Model 110 Clutch Replacement: step 8, image 3 of 3
      • Push tab and remove the connector that is next to the water level control on the inside of the control panel.
      • Pull the connector from the door safety switch located on the main body of the washing machine top.
      • Disconnect the green wire ground point inside the control panel with the ratchet and a 1/4 inch socket.
      Ask FixBot
    9. Kenmore Model 110 Clutch Replacement: step 9, image 1 of 1
      • Use the flat head screwdriver to pry out clips on left and right side on top of the machine where the control panel was.
      Ask FixBot
    10. Kenmore Model 110 Clutch Replacement: step 10, image 1 of 3 Kenmore Model 110 Clutch Replacement: step 10, image 2 of 3 Kenmore Model 110 Clutch Replacement: step 10, image 3 of 3
      • Pull the hood gently from the front to separate from the base, leaving the tub, motor, and transmission exposed.
      • Carefully tilt the washer and set it on the back panel
      Ask FixBot
    11. Kenmore Model 110 Clutch Replacement: step 11, image 1 of 2 Kenmore Model 110 Clutch Replacement: step 11, image 2 of 2
      • Remove the pump retaining clips.
      • Leave the pump hoses attached and move the pump aside.
      Ask FixBot
    12. Kenmore Model 110 Clutch Replacement: step 12, image 1 of 2 Kenmore Model 110 Clutch Replacement: step 12, image 2 of 2
      • Lift the tab and remove the motor wiring harness connector.
      • Remove the plastic clip from the transmission housing.
      Ask FixBot
    13. Kenmore Model 110 Clutch Replacement: step 13, image 1 of 2 Kenmore Model 110 Clutch Replacement: step 13, image 2 of 2
      • Remove the motor retaining clip screws with the ratchet and a 1/4 inch socket.
      • Use the flat head screw driver to pry retaining clips off of motor.
      Ask FixBot
    14. Kenmore Model 110 Clutch Replacement: step 14, image 1 of 2 Kenmore Model 110 Clutch Replacement: step 14, image 2 of 2
      • Separate the motor from the transmission.
      • Be sure to check the rubber motor coupling while it is apart. The motor and the transmission will have a plastic piece with three prongs that fit into the rubber coupling. Check to make sure plastic prongs have not broken and the rubber coupling is not cracked.
      • If the motor coupling is cracked or broken it will need to be replaced.
      Ask FixBot
    15. Kenmore Model 110 Clutch Replacement: step 15, image 1 of 3 Kenmore Model 110 Clutch Replacement: step 15, image 2 of 3 Kenmore Model 110 Clutch Replacement: step 15, image 3 of 3
      • Inside the wash tank, use the flat head screw driver to pop cap off of the agitator.
      • Remove the transmission shaft nut with the ratchet and a 7/16 inch socket.
      • Remove the agitator by pulling it from the transmission shaft.
      Ask FixBot
    16. Kenmore Model 110 Clutch Replacement: step 16, image 1 of 2 Kenmore Model 110 Clutch Replacement: step 16, image 2 of 2
      • On the bottom of the machine, remove the 3 bolts that hold the transmission in place with the ratchet and a 3/8 inch socket.
      • Gently pull the transmission out of the washer.
      Ask FixBot
    17. Kenmore Model 110 Clutch Replacement: step 17, image 1 of 3 Kenmore Model 110 Clutch Replacement: step 17, image 2 of 3 Kenmore Model 110 Clutch Replacement: step 17, image 3 of 3
      • Remove the metal washer from the transmission shaft.
      • Pry the retaining clip from the transmission shaft with the flat head screw driver.
      • Pry the spring clip from the clutch with the flat head screw driver.
      Ask FixBot
    18. Kenmore Model 110 Clutch Replacement: step 18, image 1 of 1
      • Remove the clutch.
      Ask FixBot
6 other people completed this guide.
3 Guide Comments
Nice tutorial! Thank you!
jdickes427 - Reply Share
My Kenmore washer is as same as this one, but now the agitator works, but it does not spin. So far I reached step 14, did not find anything wrong, which parts could be the problem? Clutch? Thanks
Harry Song - Reply Share
Did you find out what was wrong with it? Mine is doing the same thing.
Jacob - Reply Share
Past 24 Hours: 7
Past 7 Days: 64
Past 30 Days: 274
All Time: 19,642
