Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement
  1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement, Drive Motor Coupling: step 1, image 1 of 3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement, Drive Motor Coupling: step 1, image 2 of 3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement, Drive Motor Coupling: step 1, image 3 of 3
    • Unplug the washing machine.
    • Using a flat head screwdriver, gently wedge the end caps off of the control console in order to open it up.
    Ask FixBot
  2. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 2, image 1 of 3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 2, image 2 of 3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 2, image 3 of 3
    • Lift and swing the console upward.
    Ask FixBot
  3. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 3, image 1 of 3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 3, image 2 of 3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 3, image 3 of 3
    • Unplug the lid-switch secured under the console.
    Ask FixBot
  4. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 4, image 1 of 3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 4, image 2 of 3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 4, image 3 of 3
    • Remove the console clips using a flat head screwdriver to release the chassis.
    Ask FixBot
  5. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 5, image 1 of 3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 5, image 2 of 3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 5, image 3 of 3
    • Stand in front of the washer and remove the chassis by lifting and pulling it towards you to expose the lower components.
    Ask FixBot
  6. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 6, image 1 of 2 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 6, image 2 of 2
    • Use the flat head screwdriver to flip the restraining clips and release the drain pump.
    Ask FixBot
  7. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 7, image 1 of 2 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 7, image 2 of 2
    • Remove the drive motor by unplugging the motor connector.
    Ask FixBot
  8. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 8, image 1 of 2 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 8, image 2 of 2
    • Remove connections to the capacitor.
    Ask FixBot
  9. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 9, image 1 of 3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 9, image 2 of 3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 9, image 3 of 3
    • Place the drive motor to the side and remove the direct drive coupler by sliding it off.
    Ask FixBot
  10. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 10, image 1 of 2 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: step 10, image 2 of 2
    • Replace with the new direct drive coupler and use the end of your screwdriver to seat it flush on the drive motor.
    Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 125
All Time: 7,505
