Introduction
If your upper agitator is failing to turn under a load, this tutorial will easily instruct you how to apply the most probable fix using two common tools and a $5.99 (max) readily available part.
Kenmore Series 80 (Whirlpool).
Prior to working on unit, make sure to unplug from power source.
Open lid to washer machine to expose interior of tub and agitator.
Spin agitator by hand until small notch facing front.
Insert medium flat head screw driver into the small notch and pry cover up and off.
Looking Straight down the cam, a 7/16" head bolt can be seen.
Insert 7/16" socket with an extension to access the head of the bolt.
Using free hand, hold bottom of agitator when removing bolt.
Remove agitator from washer tub by pulling straight up.
Lower and upper agitator may come up together, or upper agitator may only come up.
If both upper and lower agitator were removed together, gently separate them.
Put lower agitator aside, you will be only working with the upper agitator.
Gently remove auger cam from the top agitator.
When removed, place cam upside down on a flat work surface.
Remove the retaining ring by sliding it straight up and off the cam shaft.
Be cognizant, during reassembly, the retaining ring fits back into the grooves on the shaft.
With the retaining ring removed, you can now access the ratcheting dogs.
Remove the 4 ratcheting dogs from their place.
Pat # 80040: 4pk Ratcheting Dogs
Insert each new ratcheting dog into the 4 available slots
Ensure that each ratcheting dog has free motion and is not hanging on anything.
Project is now ready for reassembly!
18 other people completed this guide.
20 Guide Comments
Is this the same procedure for a Kenmore Model 110? This just started happening to mine today. HELP!!!
Thanks,
lafoote@aol.com
Michael,
yes, the Model 110 is the same as the series 80 I detailed in the repair.
good luck.
THANKS Brian Gill…
How hard is it to remove and replace the clutch?
Brian…this did not fix my problem. I’m afraid its a transmission and that is to much money to do a repair on a 29 year old washer. Thanks for you good instructions and photos though.
Mike
Thank you Brian for authoring this guide. All I can say is “ I did it!!!” The ratcheting dogs cost me $7.00 , It took a bit of travel to pick them up, a visit to the neighbor to borrow the socket wrench. 7/16 was the exact size socket. I had a Kenmore 110 model ( although the Name of the washer says Kenmore 60 : why do they make life complicated??) I just needed to lift the top part of the agitator. With much gratitude and satisfaction, Louis
