Kenmore 73035 Water Filter Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
70
All Time:
3,607
Comments: 3
3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 - 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Have you ever dispensed water from your refrigerator and spit it out immediately due to its poor taste? The better question is, “Who has not swallowed bad tasting water due to an expired water filter?” Replacing a water filter is not only easy and quick to complete, but it is also inexpensive. There is absolutely NO reason anybody should be drinking anything less than clean, purified water.
Water filters do not have an endless shelf life. Having a bad water filter can cause the water in your fridge to be contaminated. It can also lead to your drinking water having a bad taste or odor. The water filter that we will be using to replace the old one is the AQUACREST DW2042FR-09. This product is NSF certified and efficient in filtering out lead, chlorine, odor, and bad taste from your drinking water. We have found the official guide from Kenmore on how to replace the water filter for this specific model. The Kenmore instruction manual has three main issues:
  1. Kenmore only provides a telephone number to call for filter replacement. There is no link to a website for ordering a replacement. There is no model number for the water filter provided either. There are many options that may not be proprietary, but are cheaper and possibly more environmentally friendly.
  2. The step for resetting the indicator light for the water filter is located on another page describing the control panel for the refrigerator. Resetting the indicator light should be completed each time the water filter is replaced. Completing this step allows the refrigerator to properly gauge the water filter. This step should be included with water filter replacement.
  3. The pictures do not supplement the instructions very well. The pictures need more context.
The following instructions will address all of these issues.
    1. Kenmore 73035 Water Filter Replacement, Water Filter: step 1, image 1 of 3 Kenmore 73035 Water Filter Replacement, Water Filter: step 1, image 2 of 3 Kenmore 73035 Water Filter Replacement, Water Filter: step 1, image 3 of 3
      • Open the side of the refrigerator with the water filter.
      • Pull the water filter cover out.
      • The water filter cover will click when it is pulled out the required length.
      • Pull the water filter cover down.
      Ask FixBot
    2. Kenmore 73035 Water Filter Replacement: step 2, image 1 of 2 Kenmore 73035 Water Filter Replacement: step 2, image 2 of 2
      • Turn the water filter 90 degrees counter clockwise.
      Ask FixBot
    3. Kenmore 73035 Water Filter Replacement: step 3, image 1 of 2 Kenmore 73035 Water Filter Replacement: step 3, image 2 of 2
      • Remove the water filter.
      • You can not pull the water filter out unless it has been fully rotated counter clockwise.
      Ask FixBot
    4. Kenmore 73035 Water Filter Replacement: step 4, image 1 of 3 Kenmore 73035 Water Filter Replacement: step 4, image 2 of 3 Kenmore 73035 Water Filter Replacement: step 4, image 3 of 3
      • Wipe away any water that leaked during the removal of the water filter.
      Ask FixBot
    5. Kenmore 73035 Water Filter Replacement: step 5, image 1 of 2 Kenmore 73035 Water Filter Replacement: step 5, image 2 of 2
      • Insert the new water filter.
      Ask FixBot
    6. Kenmore 73035 Water Filter Replacement: step 6, image 1 of 2 Kenmore 73035 Water Filter Replacement: step 6, image 2 of 2
      • Turn the water filter 90 degrees clockwise to secure in place.
      • The water filter will not move when it is fully turned.
      Ask FixBot
    7. Kenmore 73035 Water Filter Replacement: step 7, image 1 of 3 Kenmore 73035 Water Filter Replacement: step 7, image 2 of 3 Kenmore 73035 Water Filter Replacement: step 7, image 3 of 3
      • Raise the water filter cover up.
      • Slide the water filter cover back into place.
      • The water filter cover will click when it is pushed in completely.
      Ask FixBot
    8. Kenmore 73035 Water Filter Replacement: step 8, image 1 of 2 Kenmore 73035 Water Filter Replacement: step 8, image 2 of 2
      • Dispense water over the course of five minutes in cycles of 30 seconds ON and 60 seconds OFF.
      • Do not dispense water continuously for five minutes.
      • Completing this step will remove air from the water system and reduce fine particles from the new water filter.
      Ask FixBot
    9. Kenmore 73035 Water Filter Replacement: step 9, image 1 of 2 Kenmore 73035 Water Filter Replacement: step 9, image 2 of 2
      • Press and hold the Accela Ice button icon for three seconds to turn the indicator light off.
      • Discard any ice produced within the first 24 hours.
      Ask FixBot
Finish Line
3 other people completed this guide.
3 Guide Comments
It says filters are inexpensive. I don’t think $50 to $75 is inexpensive. In my opinion that’s price gouging.
Randy White - Reply Share
Press the button for several seconds to turn the indicator light off : it may extend the life of your filter. The manufacturer may have the cycle end earlier to have you buy more filters. That works with ink in copy machines. Water filters may be less forgiving.
w. gavin gilmor - Reply Share
Do you know where to find the air filters? I cannot for the life of me seem to find them.
Angela Pulido - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 70
All Time: 3,607
