Kenmore 110 Series Washing Machine Water Pump Replacement
Views: 66K
View statistics:
Past 24 Hours:
2
Past 7 Days:
39
Past 30 Days:
239
All Time:
66,364
Comments: 9
9 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
Use this guide to replace a faulty water pump on your Kenmore 110 Series Washing Machine.
    1. Kenmore 110 Series Washing Machine Water Pump Replacement, Water Pump: step 1, image 1 of 1
      • Unplug the washing machine!
      • Carefully lay washing machine on its back.
      Ask FixBot
    2. Kenmore 110 Series Washing Machine Water Pump Replacement: step 2, image 1 of 3 Kenmore 110 Series Washing Machine Water Pump Replacement: step 2, image 2 of 3 Kenmore 110 Series Washing Machine Water Pump Replacement: step 2, image 3 of 3
      • Carefully remove both wire harnesses connected to the pump.
      • Squeeze and pull back hose clamp.
      • Twist drain hose off of pump.
      • Using a 1/4" socket wrench, remove the three mounting screws.
      • Pull the pump out of place.
      • Pulling the pump away takes a little force.
      Ask FixBot
15 other people completed this guide.
Robert Trout
1,267 Reputation
5 Guides authored
Cal Poly, Team 15-43, Forte Fall 2012 Member of Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Members
60 Guides authored
9 Guide Comments
i have a speed problem with my washer ...
http://tristaterepairs.com/dryer-repair....
Andre Matthew - Reply Share
please provide info on how to test the water pump once it's removed...
Oscar Ramos - Reply Share
The instructions say nothing of the pulley belt and wheel.
I'm looking to work on a 110. 81080100
and
I have read that transmission fluid leaks out when the washer is on its side.
Is there a way to temporarily plug it?
thomas - Reply Share
My clothes are still really wet.
Tracy Schultz - Reply Share
Washer doesn't move doesn't do any thing it just hummus won't drain water
Hector Rios - Reply Share
Past 24 Hours: 2
Past 7 Days: 39
Past 30 Days: 239
All Time: 66,364
