Kenmore 110 Series Washing Machine Lid Switch Replacement
Views: 101K
View statistics:
Past 24 Hours:
7
Past 7 Days:
67
Past 30 Days:
291
All Time:
101,419
Comments: 18
2 comments on steps, 16 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
Use this guide to replace a faulty lid switch on your Kenmore 110 series washing machine.
Parts
Tools
    1. Kenmore 110 Series Washing Machine Lid Switch Replacement, Lid Switch: step 1, image 1 of 1
      • To avoid risk of electric shock, unplug the washing machine.
      • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
      • Lifting from the rear, remove the top panel.
      • Set the top panel on its rear face, with its underside facing you.
      • The top panel will still be connected to the washer by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
      Ask FixBot
    2. Kenmore 110 Series Washing Machine Lid Switch Replacement: step 2, image 1 of 2 Kenmore 110 Series Washing Machine Lid Switch Replacement: step 2, image 2 of 2
      • Using a 5/16" socket wrench or hand wrench, remove the two screws from the component cover.
      • Gripping from the bottom, pull the component cover out of the washer.
      Ask FixBot
    3. Kenmore 110 Series Washing Machine Lid Switch Replacement: step 3, image 1 of 3 Kenmore 110 Series Washing Machine Lid Switch Replacement: step 3, image 2 of 3 Kenmore 110 Series Washing Machine Lid Switch Replacement: step 3, image 3 of 3
      • Carefully unplug the two wires connected to the lid switch.
      • Remove the two Phillips screws securing the bracket.
      • Remove the green ground wire.
      • With a screwdriver, remove the single screw connecting the lid switch to the bracket.
      Ask FixBot
9 other people completed this guide.
Robert Trout
1,267 Reputation
5 Guides authored
Cal Poly, Team 15-43, Forte Fall 2012 Member of Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Members
60 Guides authored
16 Guide Comments
My Kenmore Model 110.24622300 does NOT look anything like this!
rlhaan36 - Reply Share
my model # 11088732796 is not the same as yours
glafleur1 - Reply Share
No it ia neither of those. Thank for the reply though. My washer is a 90 series.
Jenn Leffring - Reply Share
Lol I found the solution on YouTube. All it takes is a zip tie because the lid switch for he 90s series Kenmore washer is two half pieces glued together
my Kenmore washer model# is 110.24812200; series CP2654205. Cannot remove top to repair lid switch following your video! removed the three screwsf from the back but cannot get control panal to come off! Please reply soon.
bill wardle - Reply Share
Past 24 Hours: 7
Past 7 Days: 67
Past 30 Days: 291
All Time: 101,419
