Kenmore 110 Series Washing Machine Electronic Control Replacement
Views: 32K
View statistics:
Past 24 Hours:
3
Past 7 Days:
39
Past 30 Days:
163
All Time:
32,062
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Use this guide to replace a faulty electronic control on your Kenmore 110 Washing Machine.
Tools
    1. Kenmore 110 Series Washing Machine Electronic Control Replacement, Electronic Control: step 1, image 1 of 1
      • Unplug the washing machine!
      • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
      • Lifting from the rear, remove the top panel.
      • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
      Ask FixBot
    2. Kenmore 110 Series Washing Machine Electronic Control Replacement: step 2, image 1 of 3 Kenmore 110 Series Washing Machine Electronic Control Replacement: step 2, image 2 of 3 Kenmore 110 Series Washing Machine Electronic Control Replacement: step 2, image 3 of 3
      • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
      • From the bottom, pull out and remove the component cover.
      Ask FixBot
    3. Kenmore 110 Series Washing Machine Electronic Control Replacement: step 3, image 1 of 2 Kenmore 110 Series Washing Machine Electronic Control Replacement: step 3, image 2 of 2
      • Carefully remove the three wire harnesses.
      • With a phillips head screwdriver, remove the three mounting screws.
      Ask FixBot
10 other people completed this guide.
Robert Trout
1,267 Reputation
5 Guides authored
Cal Poly, Team 15-43, Forte Fall 2012 Member of Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Members
60 Guides authored
3 Guide Comments
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
R Snagg - Reply Share
I am having the same problem. Did you ever find a fix?
Paul Bennett - Reply Share
Did anyone find a fix for this problem?
Ron Rafe - Reply Share
Past 24 Hours: 3
Past 7 Days: 39
Past 30 Days: 163
All Time: 32,062
