Kazoo Diaphragm Replacement
Views: 7.1K
View statistics:
Past 24 Hours:
7
Past 7 Days:
56
Past 30 Days:
240
All Time:
7,101
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 8 - 10 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide teaches you how to replace a broken or damaged kazoo diaphragm or membrane.
The diaphragm is essential for a working kazoo. If your kazoo is out of tune or not producing sound, you most likely have a damaged diaphragm.
A functional diaphragm provides the sound you want to produce. Eventually, some diaphragms will likely burst and rip after prolonged use. You most likely need a new diaphragm if you realize your kazoo is no longer producing sound.
Before using this guide, look down the middle of the kazoo to inspect your diaphragm for any tears or holes. This guide does not damage your kazoo in any way.
Tools
    1. Kazoo Diaphragm Replacement, Diaphragm: step 1, image 1 of 1
      • Lay your kazoo down on a flat surface.
      Ask FixBot
    2. Kazoo Diaphragm Replacement: step 2, image 1 of 2 Kazoo Diaphragm Replacement: step 2, image 2 of 2
      • Untwist the cap in the middle of the kazoo and set it to the side.
      Ask FixBot
    3. Kazoo Diaphragm Replacement: step 3, image 1 of 2 Kazoo Diaphragm Replacement: step 3, image 2 of 2
      • Take the damaged diaphragm out with your fingers.
      • If you can't get the damaged diaphragm out with your fingers, turn the kazoo over and let the diaphragm fall out.
      Ask FixBot
    4. Kazoo Diaphragm Replacement: step 4, image 1 of 2 Kazoo Diaphragm Replacement: step 4, image 2 of 2
      • Take a new diaphragm and place it back into the kazoo.
      • Twist the cap back on.
      • If you don't have any kazoo diaphragms, use scissors to cut a plastic wrapper or baking paper to the size of the hole and use that instead.
      Ask FixBot
    5. Kazoo Diaphragm Replacement: step 5, image 1 of 1
      • Take some paper towel and spray isopropyl alcohol on it to wipe off any dirt or dust.
      Ask FixBot
    6. Kazoo Diaphragm Replacement: step 6, image 1 of 1
      • Finally, let the kazoo dry off for 5 minutes, and it will sound new again. Happy playing!
      Ask FixBot
Jose Meza
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 56
Past 30 Days: 240
All Time: 7,101
