Karcher WD 5.600 MP - Electrical Defect
Video Overview
  1. Karcher WD 5.600 MP - Electrical Defect, Disassembling of the device head: step 1, image 1 of 2 Karcher WD 5.600 MP - Electrical Defect, Disassembling of the device head: step 1, image 2 of 2
    • Underneath the device head are 6 Torx TX25 screews. Screew out these.
    • Then the device head can be disassembled in to 3 main parts. While pulling the pieces apart act gentle. Espacially because the motor is sanwitched by the housing parts and the grouding cable has to be pulled off. Furthermore the cable length from the board is short and shouldn't be stressed by pulling.
  2. Karcher WD 5.600 MP - Electrical Defect, Bare the PCB: step 2, image 1 of 1
    • The PCB is clampt into the housing halves and disangages while disconnecting the parts. The control knob can disengaged by pressing the detents togehter with pliers. Then the knob can be pulled out.
    • The socket - for the remote startup of the vacuum - can be pulled out as well by pulled out by screew out 2 Torx TX20 screews. This is not mandatory but thats recommended for easier assembling. Especially for realising squeezing cables.
  3. Karcher WD 5.600 MP - Electrical Defect, Seperate the PCB from the device: step 3, image 1 of 1
    • Before pulling out the plug contacts mark them for simply recontecting them afterwards (e.g. 3 dots on the plug of X3). Then disconect them.
    • There are two Torx TX25 screws to disengade. They hold a plastic part on the bottom side. In a younger version the plastic part on the bottom side is only clipped.
  4. Karcher WD 5.600 MP - Electrical Defect, Resistor soldering: step 4, image 1 of 3 Karcher WD 5.600 MP - Electrical Defect, Resistor soldering: step 4, image 2 of 3 Karcher WD 5.600 MP - Electrical Defect, Resistor soldering: step 4, image 3 of 3
    • With chilled hand soldering the resitor can be extracted. A pair of tweezers or a tip of a knife can be helpful to lift it up.
    • Solder in new part.
    • It is recommended to use an air suction while soldering. In addition a magnifier and a professional soldering system is helpful and a desoldering pump is gold.
  5. Karcher WD 5.600 MP - Electrical Defect, Assembling cables/motor: step 5, image 1 of 2 Karcher WD 5.600 MP - Electrical Defect, Assembling cables/motor: step 5, image 2 of 2
    • Hier Übersetzung einfügen
  6. Karcher WD 5.600 MP - Electrical Defect, Assembly positioning PCB: step 6, image 1 of 2 Karcher WD 5.600 MP - Electrical Defect, Assembly positioning PCB: step 6, image 2 of 2
    • Attach the plastic part back to the PCB. Put the plug contacts on the sockets.
    • Use the plastic part from the PCB to clamp it to the right position at the housing.
    • While reassembling the housing parts it is possible to observate the position of PCB through the socket hole.
  7. Karcher WD 5.600 MP - Electrical Defect, Assembly flap filter cleaning: step 7, image 1 of 2 Karcher WD 5.600 MP - Electrical Defect, Assembly flap filter cleaning: step 7, image 2 of 2
    • The filter cleaning flap is layed in only and will be hold in place by two housing parts pressed together. Because of that it is recommended to use cable ties to stick it in position. Doing this even the spring can't be lost.
  8. Karcher WD 5.600 MP - Electrical Defect, Assembly lever filter cleaning: step 8, image 1 of 1
    • Put the lever for operating the filter cleaning right in place.
  9. Karcher WD 5.600 MP - Electrical Defect, Assembly grounding cable: step 9, image 1 of 1
    • Don't forget to put the grouding cable.
  10. Karcher WD 5.600 MP - Electrical Defect, Assembly housing screews: step 10, image 1 of 1
    • Put Housing Screews TX25 back in.
  11. Karcher WD 5.600 MP - Electrical Defect, Assembly front panel: step 11, image 1 of 1
    • Attach the socket with two TX20 screews and put the operating knob back in.
    • Remove cable ties by wire cutter.
Replacing the resistor, who costs about 4 euro cent prevents you from buing a new PCB, that costs of 90-100€. Unfortunatly, the motor got no protection by a fuse or something else to prfenvent a overload on the PCB board.
7 other people completed this guide.
Special thanks to these translators:
de en
100%
Christian is helping us fix the world! Want to contribute?
Start translating ›
Christian
1,252 Reputation
3 Guides authored
9 Guide Comments
Hallo,
kurze Rückmeldung vom Ersteller. Die Abschaltung nach ca. 3sek. bei der Fernsteuerung des Saugers durch ein externes Gerät funktionierte nach der Reparatur nicht mehr. Das heißt wer diese Funktion weiterhin nutzen möchte, muss wissen ob Ihm das 100€ für die Ersatzplatine wert ist.
Grüße
Christian - Reply Share
Vielen Dank. Ohne diese Anleitung hätte ich meine Reparatur nicht geschafft. Man muss unbedingt darauf achten am Ende den Kabelbinder wieder zu entfernen sonst kann es sein dass der Sauger nicht richtig zieht. Mir hat diese Anleitung beim Zusammenbau den Hintern gerettet.
Uwe Herforth - Reply Share
Falls jemand beim Versangen von WD3, WD4,WD5, WD6 ähnliche Probleme Hat: LM358 oder LM258 kann statt dem deffekten Microchip gelötet werden. Löterfahrung vorausgesetzt, natürlich. Und damit es nicht wieder eine Lötaktion wird, gleich Dip8 dran löten, wie in diesen Video:
https://www.youtube.com/watch?v=ACNQbUNU...
Danach gerne die Lötpunkte Isolieren (Heißkleber) und ggf. ein Kühlkörper auf LM drauf
Andrey Mashkin - Reply Share
Hallo zusammen , wie kann man zerstörungsfrei das Motorgehäuse zerlegen um die Kugellager zu tauschen ?
Danke. Uli .
Oliver Ulrich - Reply Share
Vermutlich ist das Kunststoffgehäuse so verpresst, dass es nicht zerstörungsfrei zu zerlegen ist. Auch wenn ich für reparieren bin, ist es bei dem Ersatzteilpreis fraglich, ob man es günstiger repariert bekommt. Sobald man den eigenen Stundenlohn mitrechnet wohl nicht. https://www.kaerchershop-schreiber.de/de...
Grüße Christian.
Christian - Share
Past 24 Hours: 19
Past 7 Days: 127
Past 30 Days: 629
All Time: 42,532
