KYVOL CYBOVAC E20 Wheel Replacement
    1. KYVOL CYBOVAC E20 Wheel Replacement, Wheel: step 1, image 1 of 1
      • Remove both sweepers by pinching near the base of the brushes and pulling up.
      Ask FixBot
    2. KYVOL CYBOVAC E20 Wheel Replacement: step 2, image 1 of 1
      • Remove four 10 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. KYVOL CYBOVAC E20 Wheel Replacement: step 3, image 1 of 3 KYVOL CYBOVAC E20 Wheel Replacement: step 3, image 2 of 3 KYVOL CYBOVAC E20 Wheel Replacement: step 3, image 3 of 3
      • Lift the wheel to detach the tensioning spring. This step requires you to first press down on the wheel, then detach.
      • Disconnect the wheel motor from the power supply.
      • Repeat the process for the other wheel.
      Ask FixBot
Randall Morgan
380 Reputation
3 Guides authored
IUPUI, Team 1-1, Harley Summer 2023 Member of IUPUI, Team 1-1, Harley Summer 2023
IUPUI-HARLEY-SU23S1G1
4 Members
48 Guides authored
1 Guide Comment
Hey i need help bc the cable broke down and i cant find any information on what cable this is. its the one going from the wheel motor to the platine. it has 5 cables and on the one side its 6 pins but only 5 used and on the other side its 5 pins. does anybody happen to know what cable this is?
Tobias Wynendaele - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 896
