KYVOL CYBOVAC E20 Motherboard Replacement
    1. KYVOL CYBOVAC E20 Motherboard Replacement, Battery: step 1, image 1 of 2 KYVOL CYBOVAC E20 Motherboard Replacement, Battery: step 1, image 2 of 2
      • Start by laying the device on a flat surface with the logo facing up.
      • Flip the device over.
      Ask FixBot
    2. KYVOL CYBOVAC E20 Motherboard Replacement: step 2, image 1 of 2 KYVOL CYBOVAC E20 Motherboard Replacement: step 2, image 2 of 2
      • Remove two 1 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. KYVOL CYBOVAC E20 Motherboard Replacement: step 3, image 1 of 2 KYVOL CYBOVAC E20 Motherboard Replacement: step 3, image 2 of 2
      • Remove the cover.
      Ask FixBot
    4. KYVOL CYBOVAC E20 Motherboard Replacement: step 4, image 1 of 2 KYVOL CYBOVAC E20 Motherboard Replacement: step 4, image 2 of 2
      • Lift the battery.
      • Press down on the top of the white connector.
      • Remove the battery from the vacuum.
      Ask FixBot
    1. KYVOL CYBOVAC E20 Motherboard Replacement, Wheel: step 5, image 1 of 1
      • Remove both sweepers by pinching near the base of the brushes and pulling up.
      Ask FixBot
    2. KYVOL CYBOVAC E20 Motherboard Replacement: step 6, image 1 of 1
      • Remove four 10 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. KYVOL CYBOVAC E20 Motherboard Replacement: step 7, image 1 of 3 KYVOL CYBOVAC E20 Motherboard Replacement: step 7, image 2 of 3 KYVOL CYBOVAC E20 Motherboard Replacement: step 7, image 3 of 3
      • Lift the wheel to detach the tensioning spring. This step requires you to first press down on the wheel, then detach.
      • Disconnect the wheel motor from the power supply.
      • Repeat the process for the other wheel.
      Ask FixBot
    1. KYVOL CYBOVAC E20 Motherboard Replacement, Motherboard: step 8, image 1 of 2 KYVOL CYBOVAC E20 Motherboard Replacement, Motherboard: step 8, image 2 of 2
      • Remove the eight 15 mm screws on the device's underside using a Phillips #2 screwdriver
      Ask FixBot
    2. KYVOL CYBOVAC E20 Motherboard Replacement: step 9, image 1 of 2 KYVOL CYBOVAC E20 Motherboard Replacement: step 9, image 2 of 2
      • Remove the eight 10 mm screws with a Phillips #2 screwdriver to remove the bumper.
      • Disconnect the sensor wire from the front of the device.
      Ask FixBot
    3. KYVOL CYBOVAC E20 Motherboard Replacement: step 10, image 1 of 2 KYVOL CYBOVAC E20 Motherboard Replacement: step 10, image 2 of 2
      • Remove the dust bin from the device.
      Ask FixBot
    4. KYVOL CYBOVAC E20 Motherboard Replacement: step 11, image 1 of 3 KYVOL CYBOVAC E20 Motherboard Replacement: step 11, image 2 of 3 KYVOL CYBOVAC E20 Motherboard Replacement: step 11, image 3 of 3
      • Remove the main brush from the bottom of the device.
      • Remove the orange cover, then pop the brush out of its compartment.
      Ask FixBot
    5. KYVOL CYBOVAC E20 Motherboard Replacement: step 12, image 1 of 2 KYVOL CYBOVAC E20 Motherboard Replacement: step 12, image 2 of 2
      • Disconnect the ribbon cable between the top and bottom halves of the device and remove the top half away from the rest of the body.
      Ask FixBot
    6. KYVOL CYBOVAC E20 Motherboard Replacement: step 13, image 1 of 1
      • Remove the three 10 mm screws from the motherboard using a Phillips #2 screwdriver.
      Ask FixBot
    7. KYVOL CYBOVAC E20 Motherboard Replacement: step 14, image 1 of 3 KYVOL CYBOVAC E20 Motherboard Replacement: step 14, image 2 of 3 KYVOL CYBOVAC E20 Motherboard Replacement: step 14, image 3 of 3
      • Detach the connections on the motherboard carefully.
      Ask FixBot
    8. KYVOL CYBOVAC E20 Motherboard Replacement: step 15, image 1 of 3 KYVOL CYBOVAC E20 Motherboard Replacement: step 15, image 2 of 3 KYVOL CYBOVAC E20 Motherboard Replacement: step 15, image 3 of 3
      • Continue removing the connections up until you are done removing all 19 of the motherboard connections.
      • Once all plugs are disconnected, lift the motherboard out of the device.
      Ask FixBot
Blayde Johnson
184 Reputation
1 Guide authored
IUPUI, Team 1-1, Harley Summer 2023 Member of IUPUI, Team 1-1, Harley Summer 2023
IUPUI-HARLEY-SU23S1G1
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 40
All Time: 584
