Up to 20% off select tools
KPN Arizona Comfort Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
116
All Time:
1,780
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 55 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The chosen product is the KPN Arizona Comfort phone. This repair manual guides you step by step through the repair of the speaker of the KPN Arizona Comfort phone. This is a easy guide and will take approximately 30 minutes. At the end of this guide you will be able to repair the speaker of your phone by replacing the component. Something that might be challenging is that you have to put a lot of effort for some parts.
In the inner part of the product might not be sturdy so you could break apart when taking the device apart.
    1. KPN Arizona Comfort Replacement, KPN Arizona Comfort: step 1, image 1 of 3 KPN Arizona Comfort Replacement, KPN Arizona Comfort: step 1, image 2 of 3 KPN Arizona Comfort Replacement, KPN Arizona Comfort: step 1, image 3 of 3
      • Hold the phone with one hand and apply a slight pressure on the battery lid with your other hand.
      • Now you can slide open the battery lid.
      Ask FixBot
    2. KPN Arizona Comfort Replacement: step 2, image 1 of 1
      • Lift out both batteries with a prying movement.
      Ask FixBot
    3. KPN Arizona Comfort Replacement: step 3, image 1 of 3 KPN Arizona Comfort Replacement: step 3, image 2 of 3 KPN Arizona Comfort Replacement: step 3, image 3 of 3
      • Remove the following two Phillips #00 screws securing the back casing to the front.
      Ask FixBot
    4. KPN Arizona Comfort Replacement: step 4, image 1 of 3 KPN Arizona Comfort Replacement: step 4, image 2 of 3 KPN Arizona Comfort Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to pry the front from the backside.
      • Start prying at the bottom and work your way around the device.
      • Do this for every 3 cm all around.
      • If you apply too much pressure or use a sharp tool, this might damage the casing.
      Ask FixBot
    5. KPN Arizona Comfort Replacement: step 5, image 1 of 3 KPN Arizona Comfort Replacement: step 5, image 2 of 3 KPN Arizona Comfort Replacement: step 5, image 3 of 3
      • Flip the circuit board from the backside of the phone to the frontside of the phone by tilting it on the long edge
      • Make sure you do this gesture slowly and gently so the wires will not detach.
      Ask FixBot
    6. KPN Arizona Comfort Replacement: step 6, image 1 of 3 KPN Arizona Comfort Replacement: step 6, image 2 of 3 KPN Arizona Comfort Replacement: step 6, image 3 of 3
      • You are now facing the back side. Apply a little bit of pressure with the plastic opening tool on the back of the speaker so the the speaker can pop out.
      • The speaker is still attached with a wire, do not pull this.
      Ask FixBot
    7. KPN Arizona Comfort Replacement: step 7, image 1 of 2 KPN Arizona Comfort Replacement: step 7, image 2 of 2
      • Use a soldering iron to heat up the solder connected to the electric wire.
      • When the solder is fluid, carefully pull the electric wire loose.
      Ask FixBot
    8. KPN Arizona Comfort Replacement: step 8, image 1 of 2 KPN Arizona Comfort Replacement: step 8, image 2 of 2
      • Replace the broken speaker of the phone and solder it back in place.
      Ask FixBot
To reassemble your device, follow these instructions from step 6 in reverse order.
2 other people completed this guide.
Author
with
Maite
149 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 116
All Time: 1,780
