KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement
  1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: step 1, image 1 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: step 1, image 2 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: step 1, image 3 of 3
    • Insert the key cap puller into the cracks around the keycap.
    • Twist the tool around the bottom of the keycap.
    • Hold the keyboard down, and pull on the keycap slowly.
    • Pull up as straight as possible.
    • Force required to pull a keycap may vary from soft to heavy.
    Ask FixBot
  2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 2, image 1 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 2, image 2 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 2, image 3 of 3
    • Proceed to remove the surrounding keycaps.
    Ask FixBot
  3. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 3, image 1 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 3, image 2 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 3, image 3 of 3
    • Flip the keyboard over so that the bottom is facing upward.
    • Slip an opening pick beneath the warranty sticker.
    • Proceed to pull the sticker off to reveal the hole.
    Ask FixBot
  4. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 4, image 1 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 4, image 2 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 4, image 3 of 3
    • Use a Phillips #1 Screwdriver to remove the 10 mm screw.
    Ask FixBot
  5. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 5, image 1 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 5, image 2 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 5, image 3 of 3
    • Slip an opening tool into the cracks at the indicated points.
    • Pry open carefully.
    Ask FixBot
  6. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 6, image 1 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 6, image 2 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 6, image 3 of 3
    • Flip the keyboard so that the keys are facing upward.
    • Grab the sides of the top case and pull up gently.
    Ask FixBot
  7. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 7, image 1 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 7, image 2 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 7, image 3 of 3
    • Separate the plate from the bottom case slightly.
    • Reach within and remove the daughterboard cable.
    Ask FixBot
  8. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 8, image 1 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 8, image 2 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 8, image 3 of 3
    • Turn the plate over.
    • Locate the pins for the key switch.
    • All the key switches are labeled with their ASCII designation.
    Ask FixBot
  9. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 9, image 1 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 9, image 2 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 9, image 3 of 3
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Desolder the pins with a soldering iron and a desoldering pump.
    • Repeat until the pins freely move inside the wells without heat.
    • Placing the soldering iron too close to the PCB may damage it.
    Ask FixBot
  10. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 10, image 1 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 10, image 2 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 10, image 3 of 3
    • Wedge two opening tools under the key switch.
    • Pull up gently.
    • If the key switch appears to be immovable, consider repeating step 9.
    Ask FixBot
  11. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 11, image 1 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 11, image 2 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 11, image 3 of 3
    • Insert a new key switch into the well with pins corresponding to that of the PCBs.
    Ask FixBot
  12. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 12, image 1 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 12, image 2 of 3 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: step 12, image 3 of 3
    • Solder the pins onto the PCB ensuring the solder stays within the wells of the pins.
    • Ensure the pins do not freely move after soldering.
    • Ensure that there is no solder connecting the two pins, as this can possibly cause a short circuit.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order starting at step 7.
2 other people completed this guide.
Kenny Nguyen
268 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 101
All Time: 2,326
