KBD67 Lite R4 Keyboard Keys Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
59
All Time:
529
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This a guide on cleaning and replacing keys on a KBD67 Lite R4 keyboard.
Tools
    1. KBD67 Lite R4 Keyboard Keys Replacement, Remove Keycaps: step 1, image 1 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Remove Keycaps: step 1, image 2 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Remove Keycaps: step 1, image 3 of 3
      • Place keyboard on top of a flat table.
      • Remove keycaps manually or with a key cap puller, as demonstrated.
      • Organize tools to prevent loss.
      Ask FixBot
    2. KBD67 Lite R4 Keyboard Keys Replacement, Remove switches from PCB: step 2, image 1 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Remove switches from PCB: step 2, image 2 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Remove switches from PCB: step 2, image 3 of 3
      • These images showcase the correct utilization of a key switch puller.
      • Remove switches either manually or with a key switch puller.
      • A switch puller is recommended as hand removal might be difficult.
      Ask FixBot
    3. KBD67 Lite R4 Keyboard Keys Replacement, Remove case (unscrew from back): step 3, image 1 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Remove case (unscrew from back): step 3, image 2 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Remove case (unscrew from back): step 3, image 3 of 3
      • Use screwdriver to unscrew the eight screws on back of keyboard.
      • Make sure to secure screws for later use.
      Ask FixBot
    4. KBD67 Lite R4 Keyboard Keys Replacement, Remove PCB from case: step 4, image 1 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Remove PCB from case: step 4, image 2 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Remove PCB from case: step 4, image 3 of 3
      • Unscrew the PCB from case.
      • Avoid placing the PCB on static-prone surfaces to prevent it from shorting the switch sockets.
      Ask FixBot
    5. KBD67 Lite R4 Keyboard Keys Replacement, Unscrew the stabilizers: step 5, image 1 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Unscrew the stabilizers: step 5, image 2 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Unscrew the stabilizers: step 5, image 3 of 3
      • Unscrew the stabilizers from the back of the PCB.
      • Keep track of the noise-reducing foam stickers screwed between the PCB and keyboard switches.
      Ask FixBot
    6. KBD67 Lite R4 Keyboard Keys Replacement, Pull Stabilizers out of PCB: step 6, image 1 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Pull Stabilizers out of PCB: step 6, image 2 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Pull Stabilizers out of PCB: step 6, image 3 of 3
      • Use switch puller to take out stabilizers.
      • Once the stabilizers are unscrewed from the back, they can be removed from the PCB.
      • This completes the disassembly of the keyboard. Place the PCB in a static-free area.
      Ask FixBot
    7. KBD67 Lite R4 Keyboard Keys Replacement, Place PCB on foam and plastic cover: step 7, image 1 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Place PCB on foam and plastic cover: step 7, image 2 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Place PCB on foam and plastic cover: step 7, image 3 of 3
      • Place the plastic and foam cover on the bottom of the keyboard case.
      • The PCB sits on top of the foam cover.
      Ask FixBot
    8. KBD67 Lite R4 Keyboard Keys Replacement, Put stabilizers back onto PCB: step 8, image 1 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Put stabilizers back onto PCB: step 8, image 2 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Put stabilizers back onto PCB: step 8, image 3 of 3
      • Ensure noise-reducing foam stickers are in position before attaching the stabilizers.
      • Install stabilizers onto the PCB.
      • Screw where applicable.
      Ask FixBot
    9. KBD67 Lite R4 Keyboard Keys Replacement, Replace switches into hot swap PCB: step 9, image 1 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Replace switches into hot swap PCB: step 9, image 2 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Replace switches into hot swap PCB: step 9, image 3 of 3
      Tool used on this step:
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • Do not bend the switch pins.
      • Optional: You can clean the switches with a microfiber cloth.
      • Align the key switch pins with the corresponding holes on the PCB.
      Ask FixBot
    10. KBD67 Lite R4 Keyboard Keys Replacement, Put PCB back into the case: step 10, image 1 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Put PCB back into the case: step 10, image 2 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Put PCB back into the case: step 10, image 3 of 3
      • Use the eight screws saved from the third step.
      Ask FixBot
    11. KBD67 Lite R4 Keyboard Keys Replacement, Choose keycaps for Switches: step 11, image 1 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Choose keycaps for Switches: step 11, image 2 of 3 KBD67 Lite R4 Keyboard Keys Replacement, Choose keycaps for Switches: step 11, image 3 of 3
      • Choose keycaps to place onto switches.
      • Optional: If you would like, clean the keycaps with a microfiber cloth or a bristled toothbrush before reattaching them.
      Ask FixBot
    12. KBD67 Lite R4 Keyboard Keys Replacement, Test the switches and PCB: step 12, image 1 of 2 KBD67 Lite R4 Keyboard Keys Replacement, Test the switches and PCB: step 12, image 2 of 2
      • Plug the keyboard into a device of your choice and test its functions using appropriate software.
      Ask FixBot
Nathan Vieux
205 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 59
All Time: 529
