Up to 20% off select tools
K. Preflight Checklist-Motion
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
71
All Time:
1,623
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
    1. K. Preflight Checklist-Motion, Homing X&Y: step 1, image 1 of 2 K. Preflight Checklist-Motion, Homing X&Y: step 1, image 2 of 2
      • Press Home X. The hot end should move to the left towards the end stop. It will bump the end stop move to the right a few mm, than back left to the end stop and stop.
      • Measure the distance from the edge of the Top X Mount to the edge of the bearing block. Jog the hot end +10mm and re-measure. It should be 10mm larger.
      • Press Home Y. The hot end should move to the back towards the end stop. It will bump the end stop move to forward a few mm, than to the back to the end stop and stop.
      • Measure the distance from the edge of the rear corner to the edge of the bearing block. Jog the hot end -10mm and re-measure. It should be 10mm larger.
      Ask FixBot
    2. K. Preflight Checklist-Motion, Homing Z: step 2, image 1 of 2 K. Preflight Checklist-Motion, Homing Z: step 2, image 2 of 2
      • During bed leveling, you want the probe position to be at the center of the bed, not the nozzle. Once you have your X and Y coordinates calculated press Home Z
      • The probe(not the nozzle) will move to the center of the bed, Deploy the probe, raise the bed, stop once the probe is triggered, and lower the bed.
      • If your probe is slightly off center we need to correct it. Manually jog the hotend so the probe is in the center of the bed. Note the coordinates
      • Take the coordinates off the web page and replace them in homez.g and homeall.g
      • G1 X178.75 Y155.2 F10000 ; go to first probe point
      Ask FixBot
    3. K. Preflight Checklist-Motion, Motion: step 3, image 1 of 1
      • Manually jog the hot end
      • When you jog +X it will move to the right
      • When you jog +Y it will move towards the back.
      Ask FixBot
Finish Line
2 other people completed this guide.
Author
with
David Husolo
9,382 Reputation
33 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 71
All Time: 1,623
