Introduction
Go to step 1 ↓Like many push mowers, the K-Gro Power Pro has reliability issues with the motor cable and tends to become brittle over time. This guide is a step-by-step plan, on how to replace the motor cable for this mower so that you can continue to operate your mower without having to buy a brand new one.
Locate the throttle assembly on your mower on the right side of the push bar.
On close inspection of the plastic fitting, you can see that there are two "wings" that can be pinched together.
With the sliding mechanism squeezed and the wire slack, pinch the plastic wings together and push the fitting to the right out of the hole in the housing.
The loose wire can then be slid up through the groove in the steel.
