Justin Bieber Concert Microphone On/Off Switch Replacement
  1. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back panel: step 1, image 1 of 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back panel: step 1, image 2 of 2
    Tool used on this step:
    Flathead 1.5 mm Screwdriver
    $1.99
    Buy
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
    Ask FixBot
  2. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing batteries: step 2, image 1 of 1
    • Remove the 3 AAA batteries from the device.
    Ask FixBot
  3. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back half of device: step 3, image 1 of 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back half of device: step 3, image 2 of 2
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
    Ask FixBot
  4. Justin Bieber Concert Microphone On/Off Switch Replacement, Positioning device: step 4, image 1 of 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
    Ask FixBot
  5. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing PCB: step 5, image 1 of 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing PCB: step 5, image 2 of 2
    • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
    Ask FixBot
  6. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing on/off switch: step 6, image 1 of 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing on/off switch: step 6, image 2 of 2
    • Remove the 2, #8 11.7 mm Phillips Head screws on the On/Off Switch Board
    Ask FixBot
  7. Justin Bieber Concert Microphone On/Off Switch Replacement, Replacing on/off switch: step 7, image 1 of 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Replacing on/off switch: step 7, image 2 of 2
    • Remove On/Off Switch Board from its holding and detach the wires.
    • Replace the On/Off Switch Board with a new one and reattach the wires using this soldering guide
    Ask FixBot
Mike Seyman
437 Reputation
4 Guides authored
Baylor, Team 4-1, Williams Fall 2014 Member of Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 452
