Justin Bieber Concert Microphone Button Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
89
All Time:
599
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The buttons on the Justin Bieber Concert Microphone allow the user to the choose between the two programmed songs and add concert noise. The user will know if the button is broken if the button does not perform as intended. Such as not being being able to stop the song or not being able to add the concert noise.
Tools
    1. Justin Bieber Concert Microphone Button Replacement, Removing back panel: step 1, image 1 of 2 Justin Bieber Concert Microphone Button Replacement, Removing back panel: step 1, image 2 of 2
      Tool used on this step:
      Flathead 1.5 mm Screwdriver
      $1.99
      Buy
      • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
      Ask FixBot
    2. Justin Bieber Concert Microphone Button Replacement, Removing batteries: step 2, image 1 of 1
      • Remove the 3 AAA batteries from the device.
      Ask FixBot
    3. Justin Bieber Concert Microphone Button Replacement, Removing back half of device: step 3, image 1 of 2 Justin Bieber Concert Microphone Button Replacement, Removing back half of device: step 3, image 2 of 2
      • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
      • Pull apart the device once screws are loose, splitting the device in half.
      Ask FixBot
    4. Justin Bieber Concert Microphone Button Replacement, Positioning device: step 4, image 1 of 1
      • Keeping all wires connected to their attachments, place the front half of the device face down.
      Ask FixBot
    5. Justin Bieber Concert Microphone Button Replacement, Removing buttons: step 5, image 1 of 2 Justin Bieber Concert Microphone Button Replacement, Removing buttons: step 5, image 2 of 2
      • Remove the buttons by pushing them out from the front of the device. Clean or replace them as needed and place them back into the appropriate slots.
      Ask FixBot
Mike Seyman
437 Reputation
4 Guides authored
Baylor, Team 4-1, Williams Fall 2014 Member of Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 89
All Time: 599
