Community-Contributed Guide
Introduction
Go to step 1 ↓The ceramic valve can be removed and replaced quite easily. Newer Z models are described here.
Before you buy a new ceramic valve, you should try to repair it. You can save a lot of money and resources. Use this guide.
Tools
Behind the Jura sign are two screws with an oval head. They have to be removed.
These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit for their removal. If the right bit is not available, it could be done with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!!
This step shows how to remove the top cover
Remove the powder tray and all coffee beans.
The cover is fastened with three Torx T15 screws. Those are easily visible under the covers as well as the small cover on the left back side.
Remove the two Phillips screws on the bean container and remove the bean container.
Lift the cover upwards.
The ceramic valve is only pushed in. Release the detents at the bottom of the white plastic base and slide the valve to the right.
Lift out the valve.
Disconnect all connections and remove the valve.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
