Juki DDL-8700 Needle Replacement
  1. Juki DDL-8700 Needle Replacement, Needle: step 1, image 1 of 2 Juki DDL-8700 Needle Replacement, Needle: step 1, image 2 of 2
    • Turn the hand-wheel counter-clockwise (following the arrow) so that the needle position is at its highest point.
    • Make sure sewing machine is turned off and disconnected from power.
    Ask FixBot
  2. Juki DDL-8700 Needle Replacement: step 2, image 1 of 3 Juki DDL-8700 Needle Replacement: step 2, image 2 of 3 Juki DDL-8700 Needle Replacement: step 2, image 3 of 3
    • On the left side of the machine there is a presser foot lifter. Push it down to lower the foot.
    • The foot will be flush with the machine.
    Ask FixBot
  3. Juki DDL-8700 Needle Replacement: step 3, image 1 of 1
    • Remove the thread from the needle by pulling the thread towards you and out of the hole.
    Ask FixBot
  4. Juki DDL-8700 Needle Replacement: step 4, image 1 of 1
    • Loosen the needle clamp screw on the right side of the machine by turning the screwdriver in a counter-clockwise motion.
    Ask FixBot
  5. Juki DDL-8700 Needle Replacement: step 5, image 1 of 2 Juki DDL-8700 Needle Replacement: step 5, image 2 of 2
    • Remove the broken needle by firmly pulling it straight down.
    • Handle needle with causion to prevent injury.
    Ask FixBot
  6. Juki DDL-8700 Needle Replacement: step 6, image 1 of 1
    • Select the correct needle for a Juki DDL-8700, depending on your project.
    • Note the notch on the end of the needle.
    • The standard needle is 16 x 257.
    Ask FixBot
  7. Juki DDL-8700 Needle Replacement: step 7, image 1 of 2 Juki DDL-8700 Needle Replacement: step 7, image 2 of 2
    • Insert new needle into needle clamp and tighten the screw by turning the screwdriver clockwise.
    • Use one hand to keep the needle in place while you tighten the clamp with the other.
    • Make sure the notch of the needle is pointing towards the right.
    Ask FixBot
  8. Juki DDL-8700 Needle Replacement: step 8, image 1 of 2 Juki DDL-8700 Needle Replacement: step 8, image 2 of 2
    • Rethread the needle by passing the thread through the hole from left to right.
    Ask FixBot
Finish Line
Richelle
157 Reputation
1 Guide authored
UC Davis, Team 1-8, Andersen Winter 2024 Member of UC Davis, Team 1-8, Andersen Winter 2024
UCD-ANDERSEN-W24S1G8
4 Members
1 Guide authored
1 Guide Comment
How do I adjust the needle placement? My needle tend to break because it hits the hole on its way down.
Stefan Reenberg - Reply Share
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 147
All Time: 1,734
