Juki DDL-8700 Bobbin Replacement
  1. Juki DDL-8700 Bobbin Replacement, Bobbin: step 1, image 1 of 2 Juki DDL-8700 Bobbin Replacement, Bobbin: step 1, image 2 of 2
    • Diagram of the Juki Industrial Sewing Machine.
    Ask FixBot
  2. Juki DDL-8700 Bobbin Replacement: step 2, image 1 of 3 Juki DDL-8700 Bobbin Replacement: step 2, image 2 of 3 Juki DDL-8700 Bobbin Replacement: step 2, image 3 of 3
    • Slide the empty bobbin onto the bobbin winder.
    Ask FixBot
  3. Juki DDL-8700 Bobbin Replacement: step 3, image 1 of 3 Juki DDL-8700 Bobbin Replacement: step 3, image 2 of 3 Juki DDL-8700 Bobbin Replacement: step 3, image 3 of 3
    • Push the lever on the bobbin winder forward, away from you.
    Ask FixBot
  4. Juki DDL-8700 Bobbin Replacement: step 4, image 1 of 3 Juki DDL-8700 Bobbin Replacement: step 4, image 2 of 3 Juki DDL-8700 Bobbin Replacement: step 4, image 3 of 3
    • Place the spool of thread on the dual thread stand.
    • Take the loose end of the thread and guide it through the center hole of the dual thread stand.
    • Pull the loose end of the thread through the hole, to the front.
    Ask FixBot
  5. Juki DDL-8700 Bobbin Replacement: step 5, image 1 of 3 Juki DDL-8700 Bobbin Replacement: step 5, image 2 of 3 Juki DDL-8700 Bobbin Replacement: step 5, image 3 of 3
    • Holding the loose end, guide the thread through the hole near the top of the winder disk.
    • Pull the thread between the winder disks in a clockwise direction.
    • Guide the thread through any hole on the side of the bobbin.
    Ask FixBot
  6. Juki DDL-8700 Bobbin Replacement: step 6, image 1 of 2 Juki DDL-8700 Bobbin Replacement: step 6, image 2 of 2
    • Unthread the needle before pressing the pedal.
    Ask FixBot
    • Hold the thread for a few seconds while gently pressing the pedal down.
    • Continue winding the bobbin until the desired amount or until the bobbin releases.
    • Potential for machine damage: unthread the needle before pressing the pedal.
    Ask FixBot
  7. Juki DDL-8700 Bobbin Replacement: step 8, image 1 of 3 Juki DDL-8700 Bobbin Replacement: step 8, image 2 of 3 Juki DDL-8700 Bobbin Replacement: step 8, image 3 of 3
    • Cut the thread.
    • Pull the bobbin winder lever towards you to release it.
    • Slide the bobbin off of the bobbin winder.
    Ask FixBot
  8. Juki DDL-8700 Bobbin Replacement: step 9, image 1 of 3 Juki DDL-8700 Bobbin Replacement: step 9, image 2 of 3 Juki DDL-8700 Bobbin Replacement: step 9, image 3 of 3
    • Place bobbin into bobbin case.
    • Pull the thread into the slit on the side of the bobbin.
    • Guide the thread under the notch on the side of the case.
    • Pulling the thread will turn the bobbin in a counter-clockwise direction.
    Ask FixBot
  9. Juki DDL-8700 Bobbin Replacement: step 10, image 1 of 3 Juki DDL-8700 Bobbin Replacement: step 10, image 2 of 3 Juki DDL-8700 Bobbin Replacement: step 10, image 3 of 3
    • Lift the arm of the bobbin case.
    • Place the bobbin case into the machine with the opening at the top.
    • Release the arm when the bobbin case is in place.
    Ask FixBot
  10. Juki DDL-8700 Bobbin Replacement: step 11, image 1 of 3 Juki DDL-8700 Bobbin Replacement: step 11, image 2 of 3 Juki DDL-8700 Bobbin Replacement: step 11, image 3 of 3
    • Rethread the needle from left to right.
    Ask FixBot
  11. Juki DDL-8700 Bobbin Replacement: step 12, image 1 of 3 Juki DDL-8700 Bobbin Replacement: step 12, image 2 of 3 Juki DDL-8700 Bobbin Replacement: step 12, image 3 of 3
    • Turn the hand wheel counter clockwise towards you to move the needle down and back up.
    Ask FixBot
  12. Juki DDL-8700 Bobbin Replacement: step 13, image 1 of 3 Juki DDL-8700 Bobbin Replacement: step 13, image 2 of 3 Juki DDL-8700 Bobbin Replacement: step 13, image 3 of 3
    • Hold the thread while making a full rotation with the hand wheel.
    • Allow the needle to lower into the machine and rise back up to its original position.
    • Retrieve the bobbin from the bottom of the machine.
    Ask FixBot
At this point, your bobbin should be threaded and replaced. You can now return to your sewing project.
Kaylin Lee
232 Reputation
1 Guide authored
UC Davis, Team 1-4, Andersen Winter 2024 Member of UC Davis, Team 1-4, Andersen Winter 2024
UCD-ANDERSEN-W24S1G4
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 96
All Time: 953
