Up to 20% off select tools
Joy-Con ZL Switch Replacement
Views: 17K
View statistics:
Past 24 Hours:
15
Past 7 Days:
107
Past 30 Days:
483
All Time:
16,970
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 9 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
Introduction
Go to step 1 ↓
The metal cover holding the ZL switch together had broken off the switch and jammed the control
    1. Joy-Con ZL Switch Replacement, Unscrew the back cover: step 1, image 1 of 1
      • Using the Y00 Tri-Point screwdriver, remove four M1.4 x 5mm screws to loosen the hard plastic back of the Joy-Con.
      Ask FixBot
      • After the screws are removed, lift the cover to reveal the inside of the Joy-Con and locate the ZL button.
      • The button exposed could either be the ZL or the ZR depending on which Joy-Con needs to be fixed.
      Ask FixBot
    2. Tool used on this step:
      Buy
      • Use tweezers to lift the ZL button a little then pull upwards to get it back into place.
      • Once the button is back in place, place the hard cover back on the Joy-Con and screw it back on.
      Ask FixBot
      • Click the button a couple times to ensure that it's back in place and working.
      • This may either be the ZL or ZR button depending on the Joy-Con being fixed.
      Ask FixBot
    3. Joy-Con ZL Switch Replacement: step 5, image 1 of 1
      • Resume gameplay!
      Ask FixBot
    1. Joy-Con ZL Switch Replacement, The problem part: step 6, image 1 of 2 Joy-Con ZL Switch Replacement, The problem part: step 6, image 2 of 2
      • This tiny piece of metal had come off the small pcb and ribbon cable. In doing so it had jammed the switch.
      • Use the guide for un-jamming ZL switch, to remove the case screws, the top cover and the ZL switch and springs.
      Ask FixBot
    2. Joy-Con ZL Switch Replacement, Splitting it apart: step 7, image 1 of 3 Joy-Con ZL Switch Replacement, Splitting it apart: step 7, image 2 of 3 Joy-Con ZL Switch Replacement, Splitting it apart: step 7, image 3 of 3
      • Having removed the plastic button and 2 springs you uncover the switch and holding screw.
      • Remove the holding screw.
      Ask FixBot
    3. Joy-Con ZL Switch Replacement, Pop out the battery: step 8, image 1 of 2 Joy-Con ZL Switch Replacement, Pop out the battery: step 8, image 2 of 2
      • Lift the battery out of the battery chassis tray.Use a plastic splitter if necessary.
      • Do not remove the sticky tape underneath as this is unnecessary. It does not effect the repair.
      Ask FixBot
    4. Joy-Con ZL Switch Replacement, Remove the battery tray: step 9, image 1 of 2 Joy-Con ZL Switch Replacement, Remove the battery tray: step 9, image 2 of 2
      • Remove the 4 screws holding down the inner battery support chassis. This exposes the switch connector to the pcb.
      • Note the bottom left screw in this picture is shorter than the others and needs to be put back in the correct aperture.
      Ask FixBot
    5. Joy-Con ZL Switch Replacement, Pulling the plug on the problem....: step 10, image 1 of 1
      Buy
      • Gently pull on the ribbon cable to remove the plug from the socket.
      • Insert plug on new ribbon cable & switch.
      • You may need to push in the plug with plastic tweezers. Take care not to damage the cable.
      Ask FixBot
    6. Joy-Con ZL Switch Replacement, Putting it back together: step 11, image 1 of 1
      • Replace batters chassis tray and screw back into place. Note to put back the shorter screw into the correct hole.
      • Fold battery back into place. Gently push down to get the battery stuck back to the tape.
      • Adjust the ribbon cable to ensure it is not trapped. Place the switch over the alignment pin and screw down the retaining screw.
      Ask FixBot
    7. Joy-Con ZL Switch Replacement, Yippee it works!: step 12, image 1 of 3 Joy-Con ZL Switch Replacement, Yippee it works!: step 12, image 2 of 3 Joy-Con ZL Switch Replacement, Yippee it works!: step 12, image 3 of 3
      • Put the two springs back on their retaining pins and push the button back into place.
      • It should click into place and when you push on the button you should hear the switch click.
      • Fold the cover back over and check there are no trapped wires before screwing back the 4 screws on the cover to complete the repair.
      Ask FixBot
4 other people completed this guide.
Author
with
Robin Razzell
421 Reputation
2 Guides authored
1 Guide Comment
This doesn’t really cover the removal of the ZL/ZR Buttons.
It is good for removing the actual button on the mother board, but not for removing the plastic button on the remote.
OreoDestroyer93 - Reply Share
Past 24 Hours: 15
Past 7 Days: 107
Past 30 Days: 483
All Time: 16,970
