Up to 20% off select tools
Joy-Con Battery Replacement
Views: 7K
View statistics:
Past 24 Hours:
12
Past 7 Days:
75
Past 30 Days:
292
All Time:
7,003
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
If your battery is inflating like a balloon, Or is not holding a charge or not working altogether, this guide will teach you how to fix those.
      • In order to open the joy-con, remove the joy-con from the console. Then, Using the Tri-point Y00 Screwdriver, remove the four corner screws. MAKE SURE TO OPEN SLOWLY!!!
      Ask FixBot
      • After it is open, use the spudger to remove the battery connector.
      Ask FixBot
      • Using the opening pick, insert it on the side of the battery in-between the battery and the battery casing then pry the battery up.
      • IF THE BATTERY IS INFLATED, BE VERY CAREFUL!!! (Use gloves.)
      Ask FixBot
      • To fix the battery, you need a battery!
      Ask FixBot
      • Place in the new battery in the EXACT same way.
      • If the adhesive is still sticky, you can reuse it. If not, you need to put some more on. Double stick Tessa tape works great for this. Please note you will need to scrape off the old tape or use things like Goo-Be-Gone.
      Ask FixBot
    1. Tool used on this step:
      Buy
      • With the battery connector in hand, (or tweezers!) place it over the connector on the motherboard, and press down. If it does not connect together, flip over and try again.
      Ask FixBot
      • To put the case back together, then place the case right above the case and then push it together until you hear a click.
      Ask FixBot
      • In order to replace the screws, place the four screws in their respective holes and screw them in using the Tri-point Y00 Screwdriver.
      Ask FixBot
Now your Joy-con should work now.
2 other people completed this guide.
Author
with
JFix
562 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 75
Past 30 Days: 292
All Time: 7,003
