Jelly Comb Wirelress Vertical Mouse Disassembly
  1. Jelly Comb Wirelress Vertical Mouse Disassembly, Remove bottom screws: step 1, image 1 of 2 Jelly Comb Wirelress Vertical Mouse Disassembly, Remove bottom screws: step 1, image 2 of 2
    • Peel off the rubber mouse feet at the bottom of your mouse to expose 4 screws.
    • You should be able to pry it off with just your fingers but if the glue is strong you can loosen it with a hair dryer
    • Unscrew the screws.
    • Bottom should detach
    Ask FixBot
  2. Jelly Comb Wirelress Vertical Mouse Disassembly, Remove top plate: step 2, image 1 of 2 Jelly Comb Wirelress Vertical Mouse Disassembly, Remove top plate: step 2, image 2 of 2
    • This is the tricky part. There are plastic tabs keeping the plate secure to the body of the mouse under the circuit board. It's not possible to remove the circuit board without removing the plate first.
    • Two of the tabs can be pushed open. They can be hard to see since both pieces are black and it's in a tight spot
    • Once the bottom tabs are released, carefully pry the top of the plate off.
    Ask FixBot
  3. Jelly Comb Wirelress Vertical Mouse Disassembly, Detach top pieces: step 3, image 1 of 2 Jelly Comb Wirelress Vertical Mouse Disassembly, Detach top pieces: step 3, image 2 of 2
    • There are two screws keeping the two sides together. Unscrew those pieces
    • You now have access to the top of the circuit board.
    Ask FixBot
2 other people completed this guide.
Kat W
176 Reputation
1 Guide authored
1 Guide Comment
Thanks, just disassembled, I want to repair those 2 little keys on the top, my PC does not show a result, other mouses r working normally. Pressing switches, a multimeter will reveal, if they r working or not. Up to now I could not remove the upper part and hope ur instruction will solve this problem!
Cosmos - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 73
All Time: 2,011
