Jazz UltraTab C855 Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
91
All Time:
957
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
Soldering skills are required to replace the battery in this device. Check out iFixit's Soldering Skills guide for more help.
Tools
    1. Jazz UltraTab C855 Battery Replacement, Back Cover: step 1, image 1 of 1
      Ask FixBot
    2. Jazz UltraTab C855 Battery Replacement: step 2, image 1 of 1
      • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
      Ask FixBot
    1. Jazz UltraTab C855 Battery Replacement, Battery: step 3, image 1 of 1
      • Remove the yellow tape from the sides of the battery, and the surrounding components.
      Ask FixBot
    2. Jazz UltraTab C855 Battery Replacement: step 4, image 1 of 1
      • Cut the pos(+) and neg (-) wires that connect the battery to the device using wire cutters.
      • Cut the wires towards the middle. During installation of your new battery these wires will be stripped back and soldered or crimped to reattach.
      Ask FixBot
    3. Jazz UltraTab C855 Battery Replacement: step 5, image 1 of 1
      • Using a plastic opening tool or spudger, slowly pry the battery away from the board.
      • The battery is secured to the device with adhesive.
      • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Ask FixBot
    4. Jazz UltraTab C855 Battery Replacement: step 6, image 1 of 1
      • Use a two sided adhesive to secure the new battery in place.
      • Solder or crimp the wires back together to reattach to the motherboard.
      • Replace any yellow tape that you removed at the beginning to secure the wires back in place.
      Ask FixBot
Cory Hodge
201 Reputation
2 Guides authored
IUPUI, Team 1-3, Baechle Fall 2015 Member of IUPUI, Team 1-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G3
5 Members
60 Guides authored
1 Guide Comment
Very good instructions.....but where do I buy the repkacement battery from?
fremontmyers - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 91
All Time: 957
