Jazz UltraTab C1059-HL Screen Replacement
    1. Jazz UltraTab C1059-HL Screen Replacement, Screen: step 1, image 1 of 1
      • First step is to remove screws from top and bottom of device.
      Ask FixBot
    2. Jazz UltraTab C1059-HL Screen Replacement: step 2, image 1 of 1
      • Remove the back panel of the device.
      • Be careful not to brake/bend the plastic cover of your device.
      Ask FixBot
    3. Jazz UltraTab C1059-HL Screen Replacement: step 3, image 1 of 1
      • Upon removing the back panel, place the device screen down on the table.
      Ask FixBot
    4. Jazz UltraTab C1059-HL Screen Replacement: step 4, image 1 of 1
      • Remove all data strips attached to the motherboard.
      Ask FixBot
    5. Jazz UltraTab C1059-HL Screen Replacement: step 5, image 1 of 3 Jazz UltraTab C1059-HL Screen Replacement: step 5, image 2 of 3 Jazz UltraTab C1059-HL Screen Replacement: step 5, image 3 of 3
      • Remove the tape around the battery.
      • One of these pieces of tape holds down the battery connection to the mainboard.
      • Use the soldering iron to disconnect these wires.
      • You will need to use a tool to pry off the battery. It will have a good amount of adhesive holding it down.
      • Be cautious not to bend the battery when prying.
      Ask FixBot
    6. Jazz UltraTab C1059-HL Screen Replacement: step 6, image 1 of 1
      • Once the battery is removed, make sure to remove any and all data strips that are attached.
      • Then begin to unscrew the mother board.
      Ask FixBot
    7. Jazz UltraTab C1059-HL Screen Replacement: step 7, image 1 of 1
      • Remove the motherboard chip off of the device.
      Ask FixBot
    8. Jazz UltraTab C1059-HL Screen Replacement: step 8, image 1 of 1
      • Your board should look like this after taking all of the components off the screen panel.
      Ask FixBot
    9. Jazz UltraTab C1059-HL Screen Replacement: step 9, image 1 of 2 Jazz UltraTab C1059-HL Screen Replacement: step 9, image 2 of 2
      • Remove the Display Module from the screen cover.
      Ask FixBot
    10. Jazz UltraTab C1059-HL Screen Replacement: step 10, image 1 of 1
      • Now, you can replace your broken or damaged screen!
      Ask FixBot
Amanda Justiniano
231 Reputation
2 Guides authored
IUPUI, Team 1-3, Wilson Fall 2015 Member of IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 52
All Time: 716
