Jazz HDV178 Camcorder zoom switch Replacement
  1. Jazz HDV178 Camcorder zoom switch Replacement, Back Cover: step 1, image 1 of 1
    • On the back of the camcorder, the side opposite of the flip-out screen, there is a section of grooved plastic with a small arrow.
    • Press down on the grooved plastic with your thumbs.
    • Push the back cover in the direction indicated by the small arrow on the grooved plastic. The back cover should slide right off.
    Ask FixBot
  2. Jazz HDV178 Camcorder zoom switch Replacement, Battery: step 2, image 1 of 1
    • Once you have the back cover off, the camcorder should look like this.
    • Look on the battery for a model number to assure that you acquire the correct replacement part.
    • The camcorder model number is located in the red box. Verify that you have a Jazz HDV178.
    Ask FixBot
  3. Jazz HDV178 Camcorder zoom switch Replacement: step 3, image 1 of 1
    • Take the battery out by pulling up on the bottom of the battery. You should be pulling from the side of the camera where the wrist strap is attached.
    Ask FixBot
  4. Jazz HDV178 Camcorder zoom switch Replacement, Housing: step 4, image 1 of 1
    • Remove the camera mount by unscrewing the 4.5 mm screw in the hole.
    • This is the bottom of the camcorder near where the wrist strap connects.
    Ask FixBot
  5. Jazz HDV178 Camcorder zoom switch Replacement: step 5, image 1 of 1
    • Remove the 4.5 mm screw located near the battery slot.
    Ask FixBot
  6. Jazz HDV178 Camcorder zoom switch Replacement: step 6, image 1 of 1
    • Break the glue that attaches the lens cover to the camcorder by sliding the plastic prying tool beneath the circumference of the part.
    • After the glue is broken, remove the lens cover.
    Ask FixBot
  7. Jazz HDV178 Camcorder zoom switch Replacement: step 7, image 1 of 1
    • Use a small plastic pry tool to gently pry off the silver strip on the top of the camera.
    • Make sure to run the tool under the outline of the strip as you pry it off so the plastic does not snap.
    Ask FixBot
  8. Jazz HDV178 Camcorder zoom switch Replacement: step 8, image 1 of 3 Jazz HDV178 Camcorder zoom switch Replacement: step 8, image 2 of 3 Jazz HDV178 Camcorder zoom switch Replacement: step 8, image 3 of 3
    • Locate the side of the camcorder beneath the lens and on the opposite side of the wrist strap.
    • Remove the silver strip using the same process as the previous step.
    • Remove the two 4 mm screws that were hidden under the cover.
    Ask FixBot
  9. Jazz HDV178 Camcorder zoom switch Replacement: step 9, image 1 of 3 Jazz HDV178 Camcorder zoom switch Replacement: step 9, image 2 of 3 Jazz HDV178 Camcorder zoom switch Replacement: step 9, image 3 of 3
    • Pry off the rubbery cap, which covers the buttons. Use the same process as the previous two steps.
    • Slide your prying tool underneath the entire cover to ensure that the glue breaks cleanly and the cover does not snap.
    Ask FixBot
  10. Jazz HDV178 Camcorder zoom switch Replacement: step 10, image 1 of 1
    • Remove the three combined buttons so they are not misplaced.
    Ask FixBot
  11. Jazz HDV178 Camcorder zoom switch Replacement: step 11, image 1 of 2 Jazz HDV178 Camcorder zoom switch Replacement: step 11, image 2 of 2
    • Using a firm hold on both sides of the camcorder, gently pull apart the two halves. Pressure should be evenly distributed across the entire device.
    • If the camcorder does not come apart easily, double check that all of the screws are removed. Return to the previous steps for screw removal if you find a screw that is still attached.
    Ask FixBot
  12. Jazz HDV178 Camcorder zoom switch Replacement, zoom switch: step 12, image 1 of 3 Jazz HDV178 Camcorder zoom switch Replacement, zoom switch: step 12, image 2 of 3 Jazz HDV178 Camcorder zoom switch Replacement, zoom switch: step 12, image 3 of 3
    Tool used on this step:
    Buy
    • Before removing the switch, note its position for easy reassembly.
    • Use tweezers to lift the switch off of the pin.
    • Inspect the pin's motion.
    • If the pin works properly, the zoom switch may need to be replaced.
    Ask FixBot
matthew ogan
101 Reputation
1 Guide authored
Cal Poly, Team 7-34, Regan Winter 2011 Member of Cal Poly, Team 7-34, Regan Winter 2011
CPSU-REGAN-W11S7G34
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 70
All Time: 2,124
