Jazz HDV178 Camcorder Battery Replacement
    1. Jazz HDV178 Camcorder Battery Replacement, Back Cover: step 1, image 1 of 1
      • On the back of the camcorder, the side opposite of the flip-out screen, there is a section of grooved plastic with a small arrow.
      • Press down on the grooved plastic with your thumbs.
      • Push the back cover in the direction indicated by the small arrow on the grooved plastic. The back cover should slide right off.
      Ask FixBot
    1. Jazz HDV178 Camcorder Battery Replacement, Battery: step 2, image 1 of 1
      • Once you have the back cover off, the camcorder should look like this.
      • Look on the battery for a model number to assure that you acquire the correct replacement part.
      • The camcorder model number is located in the red box. Verify that you have a Jazz HDV178.
      Ask FixBot
    2. Jazz HDV178 Camcorder Battery Replacement: step 3, image 1 of 1
      • Take the battery out by pulling up on the bottom of the battery. You should be pulling from the side of the camera where the wrist strap is attached.
      Ask FixBot
2 other people completed this guide.
timothy
354 Reputation
3 Guides authored
Cal Poly, Team 7-34, Regan Winter 2011 Member of Cal Poly, Team 7-34, Regan Winter 2011
CPSU-REGAN-W11S7G34
4 Members
73 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 36
All Time: 3,953
