Up to 20% off select tools
Jam Voice Motherboard Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
66
All Time:
712
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Replacement of the motherboard located inside the Jam Voice will be achieved by dismantling the device. The speaker and battery must be disconnected.
    1. Jam Voice Motherboard  Replacement, Hard Mesh Cover: step 1, image 1 of 2 Jam Voice Motherboard  Replacement, Hard Mesh Cover: step 1, image 2 of 2
      • Insert the plastic opening tool underneath the mesh top.
      • Pry the cover open.
      • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
      Ask FixBot
    1. Jam Voice Motherboard  Replacement, Motherboard: step 2, image 1 of 1
      • Remove the four 7mm Phillips screws from the plastic cover.
      Ask FixBot
    2. Jam Voice Motherboard  Replacement: step 3, image 1 of 2 Jam Voice Motherboard  Replacement: step 3, image 2 of 2
      • Remove the four 5mm Phillips screws that hold down the speaker in place.
      • Remove the two 6mm Phillips screws that hold down the plastic casing.
      Ask FixBot
    3. Jam Voice Motherboard  Replacement: step 4, image 1 of 1
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
      • Pull the speaker up and out.
      Ask FixBot
    4. Jam Voice Motherboard  Replacement: step 5, image 1 of 3 Jam Voice Motherboard  Replacement: step 5, image 2 of 3 Jam Voice Motherboard  Replacement: step 5, image 3 of 3
      • Remove the four 7mm Phillips screws to expose the motherboard.
      Ask FixBot
    5. Jam Voice Motherboard  Replacement: step 6, image 1 of 1
      • After removing all of the screws from the plastic cover, remove it by pulling up and out.
      • Be careful not to pull and damage any of the wires.
      Ask FixBot
    6. Jam Voice Motherboard  Replacement: step 7, image 1 of 2 Jam Voice Motherboard  Replacement: step 7, image 2 of 2
      • Remove the three 5mm Phillips screws that hold the motherboard in place.
      • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
      Ask FixBot
Author
with
Hope Bukhamseen
298 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 66
All Time: 712
