Up to 20% off select tools
Jam Voice Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
15
Past 30 Days:
82
All Time:
1,316
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The battery will be replaced by dismantling the device, disconnecting the current battery and connecting a new battery.
    1. Jam Voice Battery Replacement, Hard Mesh Cover: step 1, image 1 of 2 Jam Voice Battery Replacement, Hard Mesh Cover: step 1, image 2 of 2
      • Insert the plastic opening tool underneath the mesh top.
      • Pry the cover open.
      • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
      Ask FixBot
    1. Jam Voice Battery Replacement, Motherboard: step 2, image 1 of 1
      • Remove the four 7mm Phillips screws from the plastic cover.
      Ask FixBot
    2. Jam Voice Battery Replacement: step 3, image 1 of 2 Jam Voice Battery Replacement: step 3, image 2 of 2
      • Remove the four 5mm Phillips screws that hold down the speaker in place.
      • Remove the two 6mm Phillips screws that hold down the plastic casing.
      Ask FixBot
    3. Jam Voice Battery Replacement: step 4, image 1 of 1
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
      • Pull the speaker up and out.
      Ask FixBot
    4. Jam Voice Battery Replacement: step 5, image 1 of 3 Jam Voice Battery Replacement: step 5, image 2 of 3 Jam Voice Battery Replacement: step 5, image 3 of 3
      • Remove the four 7mm Phillips screws to expose the motherboard.
      Ask FixBot
    5. Jam Voice Battery Replacement: step 6, image 1 of 1
      • After removing all of the screws from the plastic cover, remove it by pulling up and out.
      • Be careful not to pull and damage any of the wires.
      Ask FixBot
    6. Jam Voice Battery Replacement: step 7, image 1 of 2 Jam Voice Battery Replacement: step 7, image 2 of 2
      • Remove the three 5mm Phillips screws that hold the motherboard in place.
      • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
      Ask FixBot
    1. Jam Voice Battery Replacement, Battery: step 8, image 1 of 3 Jam Voice Battery Replacement, Battery: step 8, image 2 of 3 Jam Voice Battery Replacement, Battery: step 8, image 3 of 3
      Buy
      • Expose the motherboard and battery and place in a position that will be easy to access and work with.
      • Use tweezers to remove the battery's wire from the motherboard at the connection point.
      • The battery's connection point is opposite the speaker's connection point.
      • Pull the battery from the motherboard.
      Ask FixBot
Author
with
Hope Bukhamseen
298 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 15
Past 30 Days: 82
All Time: 1,316
