Jabra Freeway Speaker Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
94
All Time:
1,568
Comments: 6
3 comments on steps, 3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 40 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide explains how to replace one of the 3 main speakers in the Freeway, however all 3 speakers are removed using this guide and the process is identical. Be sure the device is completely powered off before continuing.
Tools
    1. Jabra Freeway Speaker Replacement, Front Panel: step 1, image 1 of 3 Jabra Freeway Speaker Replacement, Front Panel: step 1, image 2 of 3 Jabra Freeway Speaker Replacement, Front Panel: step 1, image 3 of 3
      • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
      • Remove the rubber pads from the bottom of the device using the spudger.
      • Remove the foam tape covering 2 hidden screws from the back of the device.
      Ask FixBot
    2. Jabra Freeway Speaker Replacement: step 2, image 1 of 3 Jabra Freeway Speaker Replacement: step 2, image 2 of 3 Jabra Freeway Speaker Replacement: step 2, image 3 of 3
      • Remove the eight 6mm T9 screws.
      • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
      Ask FixBot
    3. Jabra Freeway Speaker Replacement: step 3, image 1 of 3 Jabra Freeway Speaker Replacement: step 3, image 2 of 3 Jabra Freeway Speaker Replacement: step 3, image 3 of 3
      • Gently lift the front panel off of the device and carefully rest it to the side.
      Ask FixBot
    1. Jabra Freeway Speaker Replacement, Speaker: step 4, image 1 of 2 Jabra Freeway Speaker Replacement, Speaker: step 4, image 2 of 2
      • Gently lift the speaker out of the device using the spudger.
      • The speaker is not fixed in place, and therefore very little force is necessary to remove this component.
      Ask FixBot
    2. Jabra Freeway Speaker Replacement: step 5, image 1 of 1
      • Desolder the two wires connecting to the speaker.
      Ask FixBot
Alec Wilson
741 Reputation
5 Guides authored
UMass Dartmouth, Team 4-8, Catania Fall 2016 Member of UMass Dartmouth, Team 4-8, Catania Fall 2016
UMASSD-CATANIA-F16S4G8
2 Members
72 Guides authored
3 Guide Comments
This guide is missing something. It is titled Speaker Replacement not just removal. Useful information to complete the replacement of a faulty speaker would include where to find a replacement part or at least a part number to search for. Removing the speaker without replacing it with another is of little use. But thank you for your time and effort.
Jssamp - Reply Share
ماهو الوات والاوم لكل سماعة
Basim Alhefne - Reply Share
What are the exact technical specifications (Wattage and Ohms) for the three internal speakers used in the Jabra Freeway
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 94
All Time: 1,568
