Up to 20% off select tools
Jabra Freeway Microphone Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
17
Past 30 Days:
93
All Time:
1,578
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 45 minutes
Difficulty: Very difficult
Tools
Introduction
Go to step 1 ↓
In this guide you will be replacing the microphone of the Jabra Freeway.
    1. Jabra Freeway Microphone Replacement, Front Panel: step 1, image 1 of 3 Jabra Freeway Microphone Replacement, Front Panel: step 1, image 2 of 3 Jabra Freeway Microphone Replacement, Front Panel: step 1, image 3 of 3
      • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
      • Remove the rubber pads from the bottom of the device using the spudger.
      • Remove the foam tape covering 2 hidden screws from the back of the device.
      Ask FixBot
    2. Jabra Freeway Microphone Replacement: step 2, image 1 of 3 Jabra Freeway Microphone Replacement: step 2, image 2 of 3 Jabra Freeway Microphone Replacement: step 2, image 3 of 3
      • Remove the eight 6mm T9 screws.
      • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
      Ask FixBot
    3. Jabra Freeway Microphone Replacement: step 3, image 1 of 3 Jabra Freeway Microphone Replacement: step 3, image 2 of 3 Jabra Freeway Microphone Replacement: step 3, image 3 of 3
      • Gently lift the front panel off of the device and carefully rest it to the side.
      Ask FixBot
    1. Jabra Freeway Microphone Replacement, Microphone: step 4, image 1 of 3 Jabra Freeway Microphone Replacement, Microphone: step 4, image 2 of 3 Jabra Freeway Microphone Replacement, Microphone: step 4, image 3 of 3
      • Remove the microphone from the microphone holding slot.
      Ask FixBot
    2. Jabra Freeway Microphone Replacement: step 5, image 1 of 1
      • Desolder the two wires connecting to the microphone.
      • Please refer to the soldering technique guide for instructions on desoldering and soldering.
      Ask FixBot
Author
with
Alec Wilson
741 Reputation
5 Guides authored
UMass Dartmouth, Team 4-8, Catania Fall 2016 Member of UMass Dartmouth, Team 4-8, Catania Fall 2016
UMASSD-CATANIA-F16S4G8
2 Members
72 Guides authored
2 Guide Comments
Perfect, thank you.
Edmond Lleshi - Reply Share
Based on my limited experience with this device, the component being replaced here is the secondary, or noise-cancelling microphone - not to be confused with the primary microphone. The other video showing replacement of the motion detector seems to be actually replacing the primary microphone.
Steve MacLeod - Reply Share
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 93
All Time: 1,578
