Up to 20% off select tools
Jabra Freeway Battery Replacement
Views: 8.5K
View statistics:
Past 24 Hours:
8
Past 7 Days:
33
Past 30 Days:
133
All Time:
8,471
Comments: 15
3 comments on steps, 12 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 45 minutes
Difficulty: Very difficult
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the battery on the Freeway.
    1. Jabra Freeway Battery Replacement, Front Panel: step 1, image 1 of 3 Jabra Freeway Battery Replacement, Front Panel: step 1, image 2 of 3 Jabra Freeway Battery Replacement, Front Panel: step 1, image 3 of 3
      • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
      • Remove the rubber pads from the bottom of the device using the spudger.
      • Remove the foam tape covering 2 hidden screws from the back of the device.
      Ask FixBot
    2. Jabra Freeway Battery Replacement: step 2, image 1 of 3 Jabra Freeway Battery Replacement: step 2, image 2 of 3 Jabra Freeway Battery Replacement: step 2, image 3 of 3
      • Remove the eight 6mm T9 screws.
      • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
      Ask FixBot
    3. Jabra Freeway Battery Replacement: step 3, image 1 of 3 Jabra Freeway Battery Replacement: step 3, image 2 of 3 Jabra Freeway Battery Replacement: step 3, image 3 of 3
      • Gently lift the front panel off of the device and carefully rest it to the side.
      Ask FixBot
    1. Jabra Freeway Battery Replacement, Battery: step 4, image 1 of 2 Jabra Freeway Battery Replacement, Battery: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the rubber gasket using tweezers.
      Ask FixBot
    2. Jabra Freeway Battery Replacement: step 5, image 1 of 2 Jabra Freeway Battery Replacement: step 5, image 2 of 2
      • Remove the five 6mm T6 screws connecting the circuit board to the rear panel.
      Ask FixBot
    3. Jabra Freeway Battery Replacement: step 6, image 1 of 3 Jabra Freeway Battery Replacement: step 6, image 2 of 3 Jabra Freeway Battery Replacement: step 6, image 3 of 3
      • Remove the microphone from microphone slot.
      Ask FixBot
    4. Jabra Freeway Battery Replacement: step 7, image 1 of 3 Jabra Freeway Battery Replacement: step 7, image 2 of 3 Jabra Freeway Battery Replacement: step 7, image 3 of 3
      • Carefully use the plastic opening tool to lift the circuit board up.
      Ask FixBot
    5. Jabra Freeway Battery Replacement: step 8, image 1 of 2 Jabra Freeway Battery Replacement: step 8, image 2 of 2
      • FIRE HAZARD. Avoid damaging the battery for this step!
      • Do not use a metal tool for this step.
      • Do not bend or puncture the battery!
      • There is adhesive covering the entire lower side of the battery.
      • Insert a guitar pick or thin plastic tool of some kind to detach the old battery from the case.
      Ask FixBot
    6. Jabra Freeway Battery Replacement: step 9, image 1 of 1
      • Desolder the three wires connecting the battery.
      • Please refer to the soldering technique guide for instructions on desoldering and soldering.
      Ask FixBot
6 other people completed this guide.
Author
with
Alec Wilson
741 Reputation
5 Guides authored
UMass Dartmouth, Team 4-8, Catania Fall 2016 Member of UMass Dartmouth, Team 4-8, Catania Fall 2016
UMASSD-CATANIA-F16S4G8
2 Members
72 Guides authored
12 Guide Comments
Hey Alec,
Why does your guide to replacing the battery in the Jabra Freeway say "no parts required"?
This would be much more useful if you provide a part number and source(s) for the replacement battery. And then maybe show removing the old battery and installing the new one.
Glenn C - Reply Share
Hi,
Does anyone knows a source for the compatible battery. Since Jabra Freeway battery has 3 wires, cannot find it online. I could find compatible batteries from China websites but they were with 2 wires.
Devesh Singh Senwal - Reply Share
I am sourcing replacement batteries for the jabra freeway should be in the end of april
scuba - Reply Share
any luck finding a replacement battery yet for this device???
chcastle - Reply Share
I’m looking for the batteries, 3 of them, right now 2018 06.
DavidNS - Reply Share
Past 24 Hours: 8
Past 7 Days: 33
Past 30 Days: 133
All Time: 8,471
