Tools
Spudger4.9
Introduction
Go to step 1 ↓The bluetooth antenna in the Jabra Freeway is what allows the device to connect with your cellular device. This guide will help you to replace the antenna in the event of a failure.
Remove the rubber pads from the bottom of the device using the spudger.
Remove the foam tape covering 2 hidden screws from the back of the device.
Tool used on this step:Tweezers$4.99
Carefully remove the rubber gasket using the tweezers.
Desolder the antenna wire from the circuit board.
Please refer to the soldering technique guide for instructions on desoldering and soldering.
