Jabra Evolve2 65 Speaker Replacement
  1. Jabra Evolve2 65 Speaker Replacement, Ear Pads: step 1, image 1 of 1
    • Lay your headphones down on a flat, solid surface.
    Ask FixBot
  2. Jabra Evolve2 65 Speaker Replacement: step 2, image 1 of 2 Jabra Evolve2 65 Speaker Replacement: step 2, image 2 of 2
    • Insert an opening tool into the seam between the ear pad and driver housing, near the hinge.
    • Gently pry the ear pad away from the driver housing until it releases.
    Ask FixBot
  3. Jabra Evolve2 65 Speaker Replacement: step 3, image 1 of 2 Jabra Evolve2 65 Speaker Replacement: step 3, image 2 of 2
    • Pry off the other ear pad in the same manner.
    Ask FixBot
  4. Jabra Evolve2 65 Speaker Replacement, Motherboard: step 4, image 1 of 2 Jabra Evolve2 65 Speaker Replacement, Motherboard: step 4, image 2 of 2
    • Peel back the tape where the microphone's base connects to the headband.
    • Use a T6 Torx screwdriver to remove the single 2 mm screw.
    Ask FixBot
  5. Jabra Evolve2 65 Speaker Replacement: step 5, image 1 of 1
    • Go about a third of the way around the first screw and peel back the tape to locate the second screw.
    • Use T6 Torx screwdriver to remove the single 2 mm screw.
    Ask FixBot
  6. Jabra Evolve2 65 Speaker Replacement: step 6, image 1 of 1
    • Locate the third screw after peeling the tape off entirely after removing the second screw.
    • Use a T6 Torx screwdriver to remove the final 2 mm screw.
    Ask FixBot
  7. Jabra Evolve2 65 Speaker Replacement: step 7, image 1 of 3 Jabra Evolve2 65 Speaker Replacement: step 7, image 2 of 3 Jabra Evolve2 65 Speaker Replacement: step 7, image 3 of 3
    • Use an opening tool to pry up and set aside the driver housing.
    • Gently remove the motherboard from the housing..
    Ask FixBot
  8. Jabra Evolve2 65 Speaker Replacement: step 8, image 1 of 3 Jabra Evolve2 65 Speaker Replacement: step 8, image 2 of 3 Jabra Evolve2 65 Speaker Replacement: step 8, image 3 of 3
    • After locating the battery underneath, use a pair of tweezers to disconnect all connected cables.
    • Using tweezers, gently wiggle out the connector that joins the battery to the motherboard. The correct connector will be labeled on the motherboard and is the one that contains 2 wires, one black and one red.
    Ask FixBot
  9. Jabra Evolve2 65 Speaker Replacement: step 9, image 1 of 1
    • Using a soldering iron, desolder the driver connections from the motherboard.
    • When reinstalling the driver to the motherboard, make sure you solder the driver connections to the correct terminals. The red wire goes to the "P" and the black wire goes to the "N."
    Ask FixBot
  10. Jabra Evolve2 65 Speaker Replacement, Speaker: step 10, image 1 of 2 Jabra Evolve2 65 Speaker Replacement, Speaker: step 10, image 2 of 2
    • Remove the driver assembly.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
daniel g
91 Reputation
1 Guide authored
1 Guide Comment
Bonjour une fois le bloc en plastique atteint je n'arrive pas à déclipser les deux partie.
MAX S - Reply Share
Past 24 Hours: 6
Past 7 Days: 37
Past 30 Days: 171
All Time: 1,346
