Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓If your Jabra Evolve2 65 headphones battery is not holding a charge then the battery then the battery may be dead, which requires replacement.
The battery is an essential component that provides power to your headphones and allows them to turn on. Over time the battery will drain more quickly and not be able to hold a charge as effectively. If you notice that your devices battery does not last as long as it used to, you should replace your battery.
Make sure you power down your device before you begin.
Tools
Peel back the tape where the microphone's base connects to the headband.
Use a T6 Torx screwdriver to remove the single 2 mm screw.
2 other people completed this guide.
