Jabra Elite 85h Microphone Replacement
  1. Jabra Elite 85h Microphone Replacement, Ear Cushion: step 1, image 1 of 3 Jabra Elite 85h Microphone Replacement, Ear Cushion: step 1, image 2 of 3 Jabra Elite 85h Microphone Replacement, Ear Cushion: step 1, image 3 of 3
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
    Ask FixBot
  2. Jabra Elite 85h Microphone Replacement, Speaker: step 2, image 1 of 3 Jabra Elite 85h Microphone Replacement, Speaker: step 2, image 2 of 3 Jabra Elite 85h Microphone Replacement, Speaker: step 2, image 3 of 3
    • The foam inserts and backing tape are very delicate. Take your time when removing them, and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
    Ask FixBot
  3. Jabra Elite 85h Microphone Replacement: step 3, image 1 of 3 Jabra Elite 85h Microphone Replacement: step 3, image 2 of 3 Jabra Elite 85h Microphone Replacement: step 3, image 3 of 3
    • Repeat the previous steps for the other side, removing the foam inserts with care.
    Ask FixBot
  4. Jabra Elite 85h Microphone Replacement: step 4, image 1 of 1
    • Unscrew and remove the four T6 screws holding the speaker in place.
    Ask FixBot
  5. Jabra Elite 85h Microphone Replacement: step 5, image 1 of 1
    • Repeat the previous step for the other side, removing the four T6 screws.
    Ask FixBot
  6. Jabra Elite 85h Microphone Replacement: step 6, image 1 of 1
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
    Ask FixBot
  7. Jabra Elite 85h Microphone Replacement, Microphone: step 7, image 1 of 2 Jabra Elite 85h Microphone Replacement, Microphone: step 7, image 2 of 2
    • Remove the four screws attaching the circuit boards to the headphone enclosure.
    • The microphone is located on the lower circuit board.
    Ask FixBot
  8. Jabra Elite 85h Microphone Replacement: step 8, image 1 of 3 Jabra Elite 85h Microphone Replacement: step 8, image 2 of 3 Jabra Elite 85h Microphone Replacement: step 8, image 3 of 3
    • Remove the circuit boards from the headphone enclosure.
    • Carefully lift the bar located on the lower circuit board that contains the 24-pin ribbon cable. Remove the cable.
    Ask FixBot
If the microphone on your Jabra Elite 85h is not working, replacement could be an appropriate solution.
Ryan Callaghan
965 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 46
All Time: 1,789
